aileron push rod bearing
sandman
can someone please tell me the bearing and thread or part that is used between the aileron bell crank and the aileron control horn, the aluminium tube the bearing screws into is ok just the bearings need replacing.
1750100_L_5eb4c75e-0427-48cf-ab9e-1c6c72d2bc2b.jpg.780afe3bdd7815550380021165bdd933.jpg
Most bearing / bolt retailers should stock them, just take the old one in.
They are right hand threads on both ends, and measures the total distance of the setup before you remove them.
Also don't mention that they are off a aircraft ;-)
It looks like a Heim rod end to me. Have a look at the Aircraft Spruce catalogue, which is available on line. Under airframe parts it will show heim and a page of dimensions with part numbers.
