fly_tornado Posted April 29, 2019 Share Posted April 29, 2019 the empty weight on a Grunman is 460Kgs Specifications (AA-1A) Data from The American Trainer Owner's Manual[8] General characteristics Crew: one pilot Capacity: one passenger Length: 19.24 ft (5.87 m) Wingspan: 24.46 ft (7.46 m) Height: 6.80 ft (2.07 m) Wing area: 98 ft² (9.11 m²) Empty weight: 1,018 lb (461 kg) Max. takeoff weight: 1,500 lb (680 kg) Powerplant: 1 × Lycoming O-235-C2C flat-four engine, 108 hp (80.6 kW) Link to comment Share on other sites More sharing options...
kasper Posted April 29, 2019 Share Posted April 29, 2019 I suppose - being generous - it’s had one seatbelt removed and a placard added single occupant only and 600kg mtow with corresponding changes to the ops handbook on all load charts etc That would satisfy the requirements ... if I squint in a dark room whilst crossing my fingers. If not then .... hmmmmm 2 Link to comment Share on other sites More sharing options...
pmccarthy Posted April 29, 2019 Share Posted April 29, 2019 139 kg allowed for me plus fuel for a O-235 would not get off the ground! Link to comment Share on other sites More sharing options...
Thruster88 Posted April 29, 2019 Share Posted April 29, 2019 Could be operated by two hot women with fuel for 90mins plus reserve. Link to comment Share on other sites More sharing options...
KRviator Posted April 29, 2019 Share Posted April 29, 2019 The empty weight on my 2-seat RAAus-registered RV-9A is 445Kg, so 155kg payload. That's me + not-quite-full thanks or me + mini-me + fuel for a 3 hr junket. Until I swap it to VH, that meets my mission requirements. Link to comment Share on other sites More sharing options...
M61A1 Posted April 29, 2019 Share Posted April 29, 2019 You should be more concerned with getting your Tornados registered. 1 2 Link to comment Share on other sites More sharing options...
Downunder Posted April 29, 2019 Share Posted April 29, 2019 As long as the Grumman is flown within RAA requirements I don't really care. Single seat, 460 + 80kg pilot is 540kg. Leaves 60 kg fuel (80 odd litres) for an all up 600kg. Not bad... When you look at some of the older registered european 450/520/540 kg ultralight aircraft, it's not that much different and plenty of them are 2 seaters. Many pilots are "ctaf pilots", and just enjoy a solo morning or afternoon local flight. I don't hold that against them... 3 1 Link to comment Share on other sites More sharing options...
Litespeed Posted April 29, 2019 Share Posted April 29, 2019 I like the idea, now we just need a fair weight limit like 700 kg to allow other such craft and it could be great. A damn good aircraft often found at bargain prices. I like em a lot. Link to comment Share on other sites More sharing options...
Litespeed Posted April 29, 2019 Share Posted April 29, 2019 A side benefit even at this weight of 600 kg is the ability of the pilot to overload is severely limited compared to its tech weight limit. A tough aircraft compared to our usual fare. Jabiru excluded as they are tough at any weight limit- I am thinking in a accident if your wondering. Link to comment Share on other sites More sharing options...
aro Posted April 29, 2019 Share Posted April 29, 2019 What's the stall speed? Isn't the maximum stall speed 45 kt for RAA? 1 Link to comment Share on other sites More sharing options...
Downunder Posted April 29, 2019 Share Posted April 29, 2019 Hmmm...52kts. I wonder if the 600kg limit brings it down to 45? Link to comment Share on other sites More sharing options...
Roundsounds Posted April 29, 2019 Share Posted April 29, 2019 It’s all good, RAA MTOW 1500kg increase “imminent” ? It’d be interesting to throw this on scales. T-51 Link to comment Share on other sites More sharing options...
Downunder Posted April 29, 2019 Share Posted April 29, 2019 It’s all good, RAA MTOW 1500kg increase “imminent” Ha ha.... That's been on the "books" since about 2008..... It’d be interesting to throw this on scales. T-51 Not much of a problem one up, with the Rotax. As a 2 seater and/or the various V6's then VH Exp definately.... Link to comment Share on other sites More sharing options...
aro Posted April 30, 2019 Share Posted April 30, 2019 Hmmm...52kts. I wonder if the 600kg limit brings it down to 45? 600 kg should bring it down to 49 by my calculation. 45 would require 510kg. 1 Link to comment Share on other sites More sharing options...
djpacro Posted April 30, 2019 Share Posted April 30, 2019 My copy of the POH has Vs of 62 mph CAS at aft cg, 64 at fwd cg. Link to comment Share on other sites More sharing options...
kasper Posted April 30, 2019 Share Posted April 30, 2019 My copy of the POH has Vs of 62 mph CAS at aft cg, 64 at fwd cg. I did say as a single seater you’d still need to Criss your fingers ... that your claimed stall met the refs for RAAus might be one reason to have them crossed ... Link to comment Share on other sites More sharing options...
Thruster88 Posted April 30, 2019 Share Posted April 30, 2019 So this aircraft can currently be owner maintained, but when (if) RAA get higher MTOW it will be back to Lame maintenance? Or could the owner choose to keep it at 600kg ? Link to comment Share on other sites More sharing options...
Jaba-who Posted April 30, 2019 Share Posted April 30, 2019 Well that’s the big question. If the increased limits allow certified aircraft like Cessna 150s and similar to be included and in the rest of the aviation world those same aircraft have to be maintained professionally you can see that CASA will be very reluctant to have them maintained by unqualified people especially where there might be the potential for them to end up back on the GA register in the future. Same applies to the drive for CTA - you can bet they will need to be maintained same for that too. Link to comment Share on other sites More sharing options...
M61A1 Posted April 30, 2019 Share Posted April 30, 2019 So this aircraft can currently be owner maintained, but when (if) RAA get higher MTOW it will be back to Lame maintenance? Or could the owner choose to keep it at 600kg ? It is my understanding that outcome RAA is trying to get is similar to the current maintenance arrangement. That is, it requires professional maintenance if used for hire or reward (perhaps CTA), and owner maintained if used for private ops. They did acknowledge that CASA may not come to that party. If they can't get this arrangement, there's not much advantage in getting the weight increase. 1 Link to comment Share on other sites More sharing options...
aro Posted April 30, 2019 Share Posted April 30, 2019 My copy of the POH has Vs of 62 mph CAS at aft cg, 64 at fwd cg. So what weight limit do you need to bring the stall speed down to 45kt so it is RAA eligible? Link to comment Share on other sites More sharing options...
djpacro Posted May 1, 2019 Share Posted May 1, 2019 I don't know the rules about that. Normally performance stall speeds are stated for fwd cg, it is rare for a manual to quote aft cg as well for a small airplane. Do the rules allow calculation or do they require specific test in which case a calibrated ASI is required etc etc? Link to comment Share on other sites More sharing options...
facthunter Posted May 1, 2019 Share Posted May 1, 2019 I doubt they would permit the forward limit Cof G situation being altered as a stipulated condition but the weight difference is easy to calculate without flight testing... Nev 2 Link to comment Share on other sites More sharing options...
408059 Posted May 1, 2019 Share Posted May 1, 2019 Slightly off topic. I had a Cassutt Racer that I wanted to put on the RAA Register. Steve Bell, from RAA, was happy to consider the proposition until I mentioned the 58 knot stall speed. I researched and found someone over in the USA that had brought the stall speed down to 45 knots by putting wing tip extensions on and reducing weight. While the CofG was fine he found the aircraft uncontrollable at speeds just above the stall speed. The Cassutt Racer has small tail feathers and at that speed the elevator and rudder simply did not work well. Even if you can get the weight down on 24-1524, and the CofG sorted so you have a 45 knot stall speed, there still may be problems. 3 Link to comment Share on other sites More sharing options...
M61A1 Posted May 1, 2019 Share Posted May 1, 2019 I don't know the rules about that. Normally performance stall speeds are stated for fwd cg, it is rare for a manual to quote aft cg as well for a small airplane. Do the rules allow calculation or do they require specific test in which case a calibrated ASI is required etc etc? From memory CAO 95.55 requires the aircraft to stall at 45kts CAS or less in the landing configuration at MTOW Link to comment Share on other sites More sharing options...
M61A1 Posted May 1, 2019 Share Posted May 1, 2019 From CAO 95.55 stall speed Vso is the stalling speed, or minimum steady flight speed, at which an aeroplane is controllable with: (a) wing flaps in the landing position; and (b) landing gear extended; and © engine idling with the throttle closed; and (d) centre of gravity in the most forward position; and (e) maximum take-off weight. 1 1 Link to comment Share on other sites More sharing options...
