Daft Aviation Pictures
Phil Perry
Why did so many early jet aircraft have their engines out on the wings?
There were no props to clear the fuselage. It's guaranteed to cause asymetric thrust when one engine fails...
Was it just design inertia, lack of imagination, or because pilots expected engines on each wing?
Why engines on the wings?
Well structurally it’s helpful as the load of the engine is out on the wing making the wing structure lighter for the same loaded weights.
Given the overal thrust was not huge for the weight of the aircraft saving weight was very important if you had to lug around a couple of very heavy engines.
Consider two early jets in a meteor weigh in at 950kg (2,050lbs) and combined produce 4,000lb thrust but gobbled up 2,000kg of kero an hour at full throttle.
Airframe weight was critical.
Here is a record of the first time a Zurabatic Cartwheel was done in publi.
Highlights Of Farnborough 1951
The pilot was Janusz Żurakowski - Wikipedia
The day a dream crashed to earth
The Avro Canada Arrow was probably the first new generation military aircraft development that was killed off by government ignorance
Avro Canada CF-105 Arrow - Wikipedia
  • 3 weeks later...
