Fuel Tank Weep
My aircraft uses a composite fuel tank.
I burn 95/98 RON very very  rarely AvGas
At the top of the tank there is a circular metal plate that houses/contains the fuel gauge sender mechanism, and the three fuel pipes (Main, Aux & Return).
The plate is secured by many screws. I assume (never dismantled it) that  it is a "sandwich" type securing sealing system, utilizing a  gasket and/or sealing compound.
Recently I have noticed that this structure has developed a small fuell weep, with a brown sticky stuff oozing from the area that is weeping.
I would like to effect a good repair.
All suggestions welcome, with particular advise regarding suitable fuel resistant sealing compounds.
Thanks M61A1 - checked out your suggestions. I have no doubt that they would do the job very well BUT the cost $$$$$.
I would need to measure the plate but my estimate is its about a 100mm diam circle - I would hope for a much less costly solution.
I helped repair a leak in a top inspection hole on a wing.
It had a cork gasket. We cleaned it well with acetone an applied a sealant from an automotive store.
It was called "something" putty. I was worried it was going to be thick like muffler putty but was more like thick silicone. Worked well.
I'll try and find full name.
"Downunder, from rainy Tassie!"
I bought some rubberized cork gasket material (1.5mm) to use as a cushion / anti-rub separator between the oil tank and the bracket it sits on.  Cost me about $20 for a roll of it, certainly enough to get a few 100mm circles out of.  As far as I know it's fuel/oil resistant.  Got it from a local engineering place.
Ring around - someone will have a solution.
This stuff is the answer to any oil or fuel leak, in anything mechanical. Been around for yonks, still can't beat it.
https://www.permatex.com/products/gasketing/gasket-sealants/permatex-form-a-gasket-no-2-sealant/
That's my man! - about $12  - even I can afford that and I probably already have some cork gasket sheeting lying around that might make a new gasket.
Permatex is indeed a great fuel resistant sealant. I used it on all of the threads etc in fuel line nipples from fuel pumps and I have never had a problem. Without it even though the brass fittings have tapered threads they leaked.
Skippy, some composite gasket material (nitrile bonded, rubberised cork) could be a better choice than just plain cork gasket.
Plain cork is good for vibration and noise reduction, but the composite of cork and nitrile rubber is particularly good at stopping weeps.
