Guest Guest Posted August 9, 2006 Share Posted August 9, 2006 Greetings; An important Jabiru service bulletin has been released forall engines specifying compliance at the next 50 hourly inspection. It relates to the "Rocker Chamber Vent" Serial Numbers: 2200a- 2068 - 2439 2200b- 2 - 28 You need to drill into the engine to create a breather hole. The instructions are quite detailed and are located at the following link: http://www.jabiru.net.au/news/technical/index.html#EngineBulletins (Edited to fix error referring to 3300's) Nosmo Link to comment Share on other sites More sharing options...
