Red Posted March 29, 2020 Share Posted March 29, 2020 Please post any Links you have in this thread and I'll add them to the list Ta, Red Aerofix Jabiru Owners [email protected] | Topics Service Bulletins https://jabiru.net.au/wp-content/uploads/2019/07/JSL023-1_Jabiru-Engine-Overhauling-Build-Issues.pdf https://jabiru.net.au/wp-content/uploads/2019/02/JSB014-3_Propeller_Installation_Maintenance.pdf https://jabiru.net.au/wp-content/uploads/2019/02/JSL022-1_Fuel_pump_drain.pdf https://jabiru.net.au/wp-content/uploads/2019/02/JSB012-5_Flywheel_Screws.pdf https://jabiru.net.au/wp-content/uploads/2019/01/JSB040-2-Jabiru_-Mechanical-Fuel-Pump.pdf https://jabiru.net.au/wp-content/uploads/2018/05/JSB004-4_Oil_Pump-Cooler.pdf https://jabiru.net.au/wp-content/uploads/2018/05/JSB005-2_Early_6Cyl_Muffler.pdf https://jabiru.net.au/wp-content/uploads/2018/05/JSL014-5_Jabiru_Cylinder_Head_Inspection_DRAFT_.pdf https://jabiru.net.au/wp-content/uploads/2018/05/JSL008-2_Valve_Spring_Washer_wear.pdf https://jabiru.net.au/wp-content/uploads/2018/05/JSL007-7_Fuel_Guidance.pdf https://jabiru.net.au/wp-content/uploads/2018/05/JSL018-1_Oil_Cooler_Hoses.pdf https://jabiru.net.au/wp-content/uploads/2018/05/JSL017-1_Pattern_Parts.pdf https://jabiru.net.au/wp-content/uploads/2018/05/JSB031-3_Through_Bolt_Replacement_and_Upgrade.pdf https://jabiru.net.au/wp-content/uploads/2018/05/JSL015-1_Rotor_Button.pdf https://jabiru.net.au/wp-content/uploads/2018/05/JSL010-1_Service_intervals.pdf https://jabiru.net.au/wp-content/uploads/2018/05/JSB018-3_Jabiru_Engine_Tuning.pdf https://jabiru.net.au/wp-content/uploads/2018/05/JBS022-2.pdf <propellor flange attachment https://jabiru.net.au/wp-content/uploads/2018/05/JSL009-1_Starter_Solenoid.pdf https://jabiru.net.au/wp-content/uploads/2018/11/JSB033-2_Piston_Circlips.pdf https://jabiru.net.au/wp-content/uploads/2018/05/JSB021-1.pdf <configuration update https://jabiru.net.au/wp-content/uploads/2018/05/Starter-Motor-earth-Cable_JSL005-1.pdf https://jabiru.net.au/wp-content/uploads/2018/05/Dip-Sticks-8A035A0D-1.pdf https://jabiru.net.au/wp-content/uploads/2018/05/JSB010-3.pdf <statement of compliance to ASTM LSA https://jabiru.net.au/wp-content/uploads/2018/05/JSL004-1-Engine-Cooling.pdf https://jabiru.net.au/wp-content/uploads/2018/05/JSL002-3cancel-letter.pdf https://jabiru.net.au/wp-content/uploads/2018/05/Engine-Cooling-JSB016-1.pdf https://jabiru.net.au/wp-content/uploads/2018/05/JSB013-1.pdf <engine rocker chamber vent https://jabiru.net.au/wp-content/uploads/2018/05/Revised_Jabiru_Engine_TBO.pdf 1 Link to comment Share on other sites More sharing options...
