Yenn Posted September 28, 2019 Share Posted September 28, 2019 Does anyone know of a business capable of repairing a hand held radio? I have a Vertex VXA-150, which wouldn't turn on one day. Battery good, but screen blank and no noise. The couple of firms I have contacted only want to sell me a new radio and I already have two handhelds, the other one works but not well. Link to comment Share on other sites More sharing options...
Kyle Communications Posted September 28, 2019 Share Posted September 28, 2019 The problem is the cost to repair and availability of spare parts will now outweigh the cost of buying a new one 2 Link to comment Share on other sites More sharing options...
Downunder Posted September 28, 2019 Share Posted September 28, 2019 Yes, we live in a throw away society unfortunately...... $100 an hour for a technicial with no guarantee he can fix it. How many hours are you prepared to pay for? I see motorola took over Vertex, so there maybe no parts. https://www.apexradio.co.uk/two-way-radios/vertex-standard/ Link to comment Share on other sites More sharing options...
Kyle Communications Posted September 28, 2019 Share Posted September 28, 2019 Well its not only the rate to fix it. HH are very labour intensive but its also the time involved find the fault then the parts then ordering the parts then the freight on the parts then the time to fix it then putting it all back together etc etc..it all adds up Link to comment Share on other sites More sharing options...
fly_tornado Posted September 28, 2019 Share Posted September 28, 2019 Do you really want to be flying around with a dodgy radio? Link to comment Share on other sites More sharing options...
spacesailor Posted September 28, 2019 Share Posted September 28, 2019 Give the Old Ham radio guys a go, Lots of them have capable equipment to test for the fault. spacesailor Link to comment Share on other sites More sharing options...
Blueadventures Posted September 28, 2019 Share Posted September 28, 2019 Does anyone know of a business capable of repairing a hand held radio? I have a Vertex VXA-150, which wouldn't turn on one day. Battery good, but screen blank and no noise. The couple of firms I have contacted only want to sell me a new radio and I already have two handhelds, the other one works but not well. Mine would not turn on with the fully charged battery on. I have it mounted on the hangar wall and with a 240 volt power supply via correct voltage transformer to the two tipped jack plug it works. So use it to monitor the area free. 132.05. For some reason the battery voltage does not have a circuit to power it up. Cheap enough to treat yourself to a new one. Cheers Mike Link to comment Share on other sites More sharing options...
Phil Perry Posted September 28, 2019 Share Posted September 28, 2019 Give the Old Ham radio guys a go, Lots of them have capable equipment to test for the fault. spacesailor A well experienced Radio Ham could conceivably fix it, as many of them come from a commercial radio background. . . Worst case scenario is that you might have to take the bugger up for a flight in payment ! Link to comment Share on other sites More sharing options...
Jabiru7252 Posted September 29, 2019 Share Posted September 29, 2019 The lack of circuit diagrams and board layout doesn't help a tech either. I wonder if there is a 'reset' button hidden away or a 'special' turn on sequence that might set the thing going again. Link to comment Share on other sites More sharing options...
Richard Budge Posted September 29, 2019 Share Posted September 29, 2019 Andrew AIRSIDE ELECTRICAL 17 Nyrang Circuit Woodcroft Adelaide South Australia 5162 Tel +61 435365646 Link to comment Share on other sites More sharing options...
spacesailor Posted September 29, 2019 Share Posted September 29, 2019 Magic button = $. Lots off $. Seem to remember a quote. Throw lots of money at it & the problem goes away. Or something to similar to that . spaesailor Link to comment Share on other sites More sharing options...
Roscoe Posted September 29, 2019 Share Posted September 29, 2019 Yenn i sent you a PM this morning that may interest you but not sure if if it went through properly. Regards Ross Link to comment Share on other sites More sharing options...
Yenn Posted September 29, 2019 Author Share Posted September 29, 2019 Haven't seen the PM, but not sure where it would turn up. My radio doesn't work with the 240V charger. Link to comment Share on other sites More sharing options...
Roscoe Posted September 29, 2019 Share Posted September 29, 2019 Gday again Yenn Not sure why the PM not working but i have an as new Icom A-15 Handheld surplus to my requirements that you can check out in Classifieds. Link to comment Share on other sites More sharing options...
Kyle Communications Posted September 29, 2019 Share Posted September 29, 2019 Most of the Icom and Vertex HH radios have a seperate charge pcb built in or in the unit also they have a turn on FET. Your press button turn on types use a "electronic switch" instead of a normal type switch. The screen being blank could be a crook microprocessor or possible turn on power issue. Phil and Spacesailor Most hams would not be capable handling 0602 size SMD components 0805 size I work with every day and occasionally 0602 and I struggle with hand building let alone repairing 0602 and I have had 30 years of doing this this level of repair/development. Pretty much all HH are built with these size passives now not to mention the size of the SMD ic's. Yenn...spend the bucks and treat yourself to a new one 1 Link to comment Share on other sites More sharing options...
Yenn Posted September 30, 2019 Author Share Posted September 30, 2019 I don't want a new one. I have a good Icom A200 in the RV and I can fly Norad in the Corby or use my Icom Hand held. I was just wondering about the good old Yaesu. I think Kyle has probably hit the nail on the head. Link to comment Share on other sites More sharing options...
facthunter Posted September 30, 2019 Share Posted September 30, 2019 It is now the way of the world. When it stops chuck it. Many mass produced items are materials cost, Plus bu**er-all. It just isn't economic to even look at it. This takes a bit of adjusting to when one comes from a background of engine reconditioning, where one would totally remanufacture the entire engine. Now this is only done for collectables and specials. Sport Aviation needs all these skills but where does one obtain them? Nev Link to comment Share on other sites More sharing options...
Yenn Posted September 30, 2019 Author Share Posted September 30, 2019 I have sent the radio to a repairer who will quote on repair cost. Will keep you informed about the outcome. Link to comment Share on other sites More sharing options...
Yenn Posted October 18, 2019 Author Share Posted October 18, 2019 My Icom also died, the handheld that is. I never liked it as much as the Yaesu. The Yaesu was deemed repairable and is now done, just waiting for delivery. The repairer is VK Radio Repairs of Thomastown Victoria. The defect was a faulty startup clock, whatever that means. I was pleased to get it repaired as I don't like our throw away society. 2 Link to comment Share on other sites More sharing options...
Kyle Communications Posted October 18, 2019 Share Posted October 18, 2019 probably faulty crystal. Link to comment Share on other sites More sharing options...
SilverHammer Posted October 18, 2019 Share Posted October 18, 2019 There is a cpu reset to try first. Press and hold the monitor button AND hold the PTT button down while turning the unit on. After that you'll need a radio tech. I have a copy of the service manual if you need it. Link to comment Share on other sites More sharing options...
