ClintonB Posted June 21, 2019 Share Posted June 21, 2019 Hi All, I cannot figure out how to get a plan started on Oz runways without it selecting me at home with a 5 mile leg to point of origin ie home to YSTW. When i tap airfield it only has option to add to plan, not start from there. Is there something i am missing. I want to print plan sheet which I can only do at home. Any tips appreciated. thanks Link to comment Share on other sites More sharing options...
Blueadventures Posted June 21, 2019 Share Posted June 21, 2019 Hi All, I cannot figure out how to get a plan started on Oz runways without it selecting me at home with a 5 mile leg to point of origin ie home to YSTW. When i tap airfield it only has option to add to plan, not start from there. Is there something i am missing. I want to print plan sheet which I can only do at home. Any tips appreciated. thanks Send them a question. They get a reply back quick. Great team to deal with. I have rwy on android so can't help. 1 Link to comment Share on other sites More sharing options...
ClintonB Posted June 21, 2019 Author Share Posted June 21, 2019 thanks. will do 1 Link to comment Share on other sites More sharing options...
pmccarthy Posted June 21, 2019 Share Posted June 21, 2019 Make sure it doesn’t think you are flying. Ie hit cancel near top right. Then tap the aerodrome and select set as origin of plan. 2 Link to comment Share on other sites More sharing options...
kaz3g Posted June 21, 2019 Share Posted June 21, 2019 The easiest way to prepare a plan is to do it on the chart. Find the airport of departure on the chart and tap on it (if it has a little camera symbol tap near it) and select your airport as “origin” from the drop down box. Find your next intended landing point and do the same...etc. Link to comment Share on other sites More sharing options...
frank marriott Posted June 21, 2019 Share Posted June 21, 2019 Just select Quick Plan and enter your waypoints - then no reference to your current location. 1 Link to comment Share on other sites More sharing options...
ClintonB Posted June 22, 2019 Author Share Posted June 22, 2019 Thanks for the info all. Will test out on tomorrow’s flight. Cheers Clinton Link to comment Share on other sites More sharing options...
RocketShip Posted June 22, 2019 Share Posted June 22, 2019 I know someone else that has this same problem, we have tried to stop it but haven't been able to, will be interested to see the solution. Link to comment Share on other sites More sharing options...
ClintonB Posted June 30, 2019 Author Share Posted June 30, 2019 The hit cancel worked a treat, picked my first tap as origin. Easy to do that way. Link to comment Share on other sites More sharing options...
Yenn Posted June 30, 2019 Share Posted June 30, 2019 I used a trial of OZ Runways, but decided to stick with Avplan, but I had no problems making a flight plan. The instructions were clear and worked for me. From memory it was similar to Avplan, which has a "new flightplan" button, then just pick a start point, a finish point and you can put points between. Link to comment Share on other sites More sharing options...
