Hello all, I was wondering if anyone has experience fitting the Dynon D10A, I have a Jab 230D with the option1 panel but would like to fit the D10A to make it an option 2 panel. What I am interested in is, do I need to buy the optional harness from dynon or will it just slot in with the original wiring?091_help.gif.c9d9d46309e7eda87084010b3a256229.gif
The soldering is fiddlely but not to hard to do. The D10A only requires a + and a - connection to work. If your G P S goes to the aircraft earth one extra wire is required for it to pass info to the D10A. To get all the features you need the remote compass module as this is the only way to get temp info to the D10A. This will give T A S and instant wind velocity. Worth buying the wiring loom if you go for this option.
