Guest eland2705
G'day 'Dog,
Sorry I can't help you with how to get them open, but I would like to know how they feel to you?
I am look at buying a set of CH pedals (the control yoke and throttle quadrant) for our FSx system.
Do you have any comment, positive or negative
Regards
Eland...I have used the CH Products pedals and yoke and found them to be a bit light on - they are still a good set.
I now use the Saitek pedals and yoke which in my personal opinion are a lot more solid and a better feel
Flying Dog: I have pulled mine apart it's not too hard, just make sure you take note of where everything was when you pull the bottom off. If I remember correctly there are a couple of springs that you have to hold in place when putting them back together but no major concerns.
eland: I am not that happy with mine, within 12 months of light use the toe brake on the left pedal is stuck on about half the time and makes ground handling quite difficult.
AllanW,
So it is done by the bottom, huh?
Does that get access to the brake mechanisum?
To me that looks like it is in the pedal part rather than the base.
When I get some time I shall sit down and take it appart from the bottom.
Thanks.
