Hello all ,
thanks for the info that has assisted me greatly on other threads,
however I need some help again.
I Need to confirm the
1 weight of Junkers BRS factory fitted to an Allegro 2000
2 cost of a a 6 yearly re pack ( must this be done ? )
3 rocket 10 yr or 12 year lifespan ( do you discard whole system after ? )
4 I was also told that the weight of the BRS is not considered in MTOW
( this does not sound right to me !! ) but could understand it being the case
if the aircraft was subject to 544 kg RAA but was also able to be CASA
registered at a higher MTOW ie Jab 230 ?
Thanks in advance I hope
The weight of the BRS is included in the MTOW of the aircraft.
You need to recalculate the weight & balance of the aircraft once fitted.
Depends on the brand but the weight is about 15 kg's.
Mick
