I have recently reconditioned the carby's on my Lightwing GR 912 80hp.Closer inspection found small fragments of the air intake hose in the carby.It is the flexible orange Scat hose with wire reinforcing linking the carby to the air cleaner.It obviously in need of replacment but all the orange reinforced scat or sceet hose I am able to source is technically not suitable because they are not recomended for a negative pressure situation which is created in the intake hose.I did notice that a Skyfox had a forced landing in 2000 due to the scat hose collapsing and blocking the air intake.
I would be interested what other people are using and where do I source it.
Thanks
Thanks.I did speak to Floods but they don't supply it.
Guest milton56
Talk to the guys at Superior in Archerfield ( Brisbane), they helped me with this issue.
Thank you I spoke to Superior but they found that the sceet hose is no longer recommended due to the negative pressure even though it is still widely used in these situations.I have since rang Lightwing and they are supplying what they use I suspect it will be the same sceet hose.At least it has lasted 900hours!!!
  • 1 year later...
Thank you I spoke to Superior but they found that the sceet hose is no longer recommended due to the negative pressure even though it is still widely used in these situations.I have since rang Lightwing and they are supplying what they use I suspect it will be the same sceet hose.At least it has lasted 900hours!!!Cheers
Hi how is the hose holding up and haow muck did it cost and postage when you bought it.
Thanks
Mike
I don't use scat or sceet in the induction system. I have a mix of solid rubber hose like radiator hose and fibreglass solid ducting. The rubber allows for movement.
