Guest disperse Posted September 25, 2010 Posted September 25, 2010 I'm sure the answer is simple......... once I know it:big_grin: Thanks Troy
FlyingVizsla Posted September 25, 2010 Posted September 25, 2010 One's for talking on (Coms - Communication) the VHF radio The other's for radio assisted navigating (Nav Coms) - the NDB - Non Directional Beacon where you dial in the frequency and the needle moves to point to it (yeah, there's a bit more to it ...) - the DME - Distance Measuring Equipment - ditto but digital read out - the VOR - etc. Sue
jetboy Posted September 25, 2010 Posted September 25, 2010 Com refers to the usual VHF radio Navcom refers to a unit with the same radio plus a VOR navigation decoder included and a VOR display instrument. Fairly obsolete now especially in rec. flying not much VOR coverage at the levels we fly. i tried one in a Bantam once had to get hypoxic before it would start to work. ADF not much good either, too much crab angle in a Bantam with a crosswind! Usually they had a nav side and a com side, the nav part having its own antenna and separate receiver so both functions could be used simultaneously. Some particularly crude types like the Narco Escort shared the reciever and had to be switched manually between functions. Ralph
Guest disperse Posted September 26, 2010 Posted September 26, 2010 Thank you..... Just wasn't sure what sort of Nav they have. Regards
facthunter Posted September 27, 2010 Posted September 27, 2010 Radio Fail procedures. You can put comm messages over the ident frequency of some navaids in radio fail situations near airports in control areas. This might have been discontinued. Some ATC person may clarify..Nev
Mazda Posted September 29, 2010 Posted September 29, 2010 As stated above, it is a VHF and VOR in one box. The VOR is not obsolete, it is still used regularly by those navigating by instruments.
