pudestcon Posted October 18, 2010 Posted October 18, 2010 My Thruster will be fitted with a s/h prop from a Thruster that I did all my conversion training in, so I know the prop is serviceable. The prop does look a little shabby so I want to paint it to look like new. It's a 3 blade composite prop (sorry don't know the brand) so how do I go about painting it? Sand it back, primer, top coats, what sort of paint? All questions I need answers to, and I'm sure you guys will be able to give me much advice about it:big_grin: Cheers, Pud
Mick Posted October 18, 2010 Posted October 18, 2010 Pud, I would be very wary of painting a prop unless you have an appropriate way of re-balancing it when you are done. Cheers Mick
pudestcon Posted October 18, 2010 Author Posted October 18, 2010 Pud,I would be very wary of painting a prop unless you have an appropriate way of re-balancing it when you are done. Cheers Mick G'day Mick, and thanks for replying. Yeh I am aware that the prop will need rebalancing, and that is something I need to study up on before I attempt any painting. I'll need to hit the books and ask lots of questions to see if it is a DIY project or all too hard (and safer:helmet:), so leave it alone. Cheers, Pud
Guest davidh10 Posted October 18, 2010 Posted October 18, 2010 Pud; Since the prop is composite, why not just some polish. The coating is too thin to cause unbalance, but makes an old prop look much better. It does have to be reapplied periodically.
pudestcon Posted October 18, 2010 Author Posted October 18, 2010 Pud;Since the prop is composite, why not just some polish. The coating is too thin to cause unbalance, but makes an old prop look much better. It does have to be reapplied periodically. Good point david, I didn't think about polishing - what would you recommend using? Pud
pudestcon Posted October 19, 2010 Author Posted October 19, 2010 After looking at the prop today I reckon a coat of clear lacquer will do the trick. Here's a photo of the prop - what do you think? Pud
tvaner Posted October 19, 2010 Posted October 19, 2010 I'd be surprised if a light coat of ArmorAll wouldn't bring that up as new Pud.
pudestcon Posted October 19, 2010 Author Posted October 19, 2010 I'd be surprised if a light coat of ArmorAll wouldn't bring that up as new Pud. OK tvaner, That's what I'm gonna try then. I'll let you know how I go. Thanks Pud
JG3 Posted October 19, 2010 Posted October 19, 2010 That's a Brolga prop, and this is how I had mine painted for years. No problems. Just clean the blades thoroughly with turps then scrub with a jex pad and paint. Keep the paint as thin as possible. Balance by spraying more coats of clear laquer on the lightest blade. If you've already tried ArmorAll then the paint won't stick at all......
Tomo Posted October 19, 2010 Posted October 19, 2010 Spray/brush You would want to spray paint it wouldn't you? to ensure a complete even coating. If you used a brush, my thoughts would be highly uneven coating? Btw JG3, your prop always stands out really well.
pudestcon Posted October 19, 2010 Author Posted October 19, 2010 Well your prop really stands out eh JG3? I'm just gonna leave mine black with yellow tips probably to match the pod on the Thruster. Spraying would be the way to go Tomo for an even, uniform and light cover
JG3 Posted October 19, 2010 Posted October 19, 2010 Yes, definitely spray. Aerosol cans are ideal - it's only a small area and the enamel paint adheres well.
Harthy Posted October 19, 2010 Posted October 19, 2010 What ever you decide to do with the prop, do not put polish on it (Silicon Polish) as any type of repairs will not be able to be carried out if needed. The old Brolga prop builder told me that. Can't think of his name at the moment. Lanoline will keep them looking good. Harthy
Guest davidh10 Posted October 20, 2010 Posted October 20, 2010 Good point david,I didn't think about polishing - what would you recommend using? Pud I'm using Aeroshell Flightjacket Polish. Info on Shell's web site. I'm also using some of their other products in this series including the Interior Conditioner. These don't leave an oily residue that attracts dust. I'm aware of a blade that has been recently repaired after using this polish regularly for over a year. No problem.
XAIRVTW Posted October 20, 2010 Posted October 20, 2010 Armoral has silicone it as well. best polish is bees wax use it all the time in my work shop. cheers
Ultralights Posted October 20, 2010 Posted October 20, 2010 anything with Silicon in it should be kept well away from any composites, even masking tape has silicones in its adhesive and not recommended to be used in a composites workshop.
nashy Posted October 20, 2010 Posted October 20, 2010 Iv'e been using auto cut and polish for years on my ivo prop and it look like new.
XAIRVTW Posted October 21, 2010 Posted October 21, 2010 I use 3m masking tape in my spray booth this stuff has no silicone in it. Wouldnt use any other brand.
Pilot Pete Posted October 21, 2010 Posted October 21, 2010 It should'nt really matter what type of polish or cleanersd you use. If you do any painting you should give the area a wipe down with Prepsol or other simular wax/grease/silicone remover. I have used this for years on all surfaces including composite that has had grease,oil silicone,bug guts and all manner of polishes rubbed into it and it does a great job of removing it. Even after sanding you should use it as a lot of sandpapers have silicone on them.
