the professor Posted October 25, 2010 Posted October 25, 2010 Does anybody know of a source for the plastic connectors that terminate the CHT probes as supplied by Jabiru? I have tried the usual electronic suppliers such as Jaycar without success. Colin
Captain Posted October 25, 2010 Posted October 25, 2010 Does anybody know of a source for the plastic connectors that terminate the CHT probes as supplied by Jabiru? I have tried the usual electronic suppliers such as Jaycar without success.Colin Colin, I can't give you a direct answer, but I do think that the total resistance of those systems is critical, so the right bits need to be used. I suggest that you work back from whoever made the gauge that is in your aircraft. I have Dynon units in mine and would only ever use Dynon components if anything is ever needed. Same comments re the EGT's as well, in my opinion. Sorry if this is only a part answer, but I hope it helps in some way. Regards Geoff
the professor Posted October 25, 2010 Author Posted October 25, 2010 Thanks Geoff, Yes, I am aware of the issues involved. It is simply a matter of Jabiru only being able to supply a complete probe - and all I need is the terminating connector. They appear to be made from unobtainium! Regards, Colin.
Guest 4aplat Posted October 25, 2010 Posted October 25, 2010 Just cut the plug and switch with this (don't know the name in english) or Don't spend too much time looking at your gauges, I broke an 2200 jab with corrects T° MicheL
