Guest P300NZ Posted November 18, 2010 Share Posted November 18, 2010 I fly a Alpi Pioneer P300 with a Jabiru 3300A and have discovered a oil leak at the mechanical fuel pump. Suspect a distorted spacer block which looks to be a plastic or composite material. Has any body had a similar problem Link to comment Share on other sites More sharing options...
dazza 38 Posted November 18, 2010 Share Posted November 18, 2010 Welcome Mate, sorry i cant help you with your Jabiru problem.Someone here will. Link to comment Share on other sites More sharing options...
Guest davidh10 Posted November 18, 2010 Share Posted November 18, 2010 Welcome P300NZ. I'm also sure you will find someone to help, but as this is an "introduce yourself" Forum, I suggest you post your question as a thread in the Jab Forum. More Jab owners will likely see it then.:) Link to comment Share on other sites More sharing options...
Guest Wigg Posted November 20, 2010 Share Posted November 20, 2010 Welcome P300NZ sorry can't help you with your problem. Are you from the North or South Island? Regards Sue Link to comment Share on other sites More sharing options...
Guest P300NZ Posted November 22, 2010 Share Posted November 22, 2010 Hi Sue I am based on an airstrip on the Coromandel peninsular in the North Island. It is a beach resort with a small permanent population. Cheers Link to comment Share on other sites More sharing options...
