farri Posted November 24, 2010 Posted November 24, 2010 A local guy with a Rotax 582 wants to use a different oil in the fuel mix and he`s been told to use Castrol 2T, he want`s to know if this is correct. I use Castrol 2T in my Rotax 503 and to my knowledge this oil is for air cooled engines only. Will 2T be suitable for the 582? Frank.
facthunter Posted November 24, 2010 Posted November 24, 2010 Castrol oil 2- stroke. I would upgrade from that . The highest performance is (a) Castrol Power 1 Racing 2T Or (b) " Power 1 TTS 2T These are both recommended for Liquid cooled motors with higher performance. Nev
farri Posted November 24, 2010 Author Posted November 24, 2010 Thanks Nev, I`ll pass it on. I wasn`t aware of the Castrol power 1 racing 2T. Is 2T suitable for the 582 though.
Methusala Posted November 24, 2010 Posted November 24, 2010 Having a 582, I did a lot of reading (I won't be pretentious and call it research!) on 2 stroke oils. Castrol Activ 2T seemed to be a very popular choice since the demise of Penrite T40 C. I have used it for 30 odd hours but have no objective measure of its quality. I don't normally "put my faith in the market", but I believe that Castrol would have a lot to lose by selling a poor product. By the way, compared with motor bikes I don't think that the 582 is a high performance engine. The oil that Facthunter refers to is a fully synthetic oil and one recurring opinion about synthetics is that they quickly drain away from metal surfaces (such as cylinder walls), and so don't offer start up protection in engines that are used somewhat infrequently. There are many urban myths out there and once again I offer my thoughts on a take it or ignore it basis. Just my thoughts. Don
pudestcon Posted November 24, 2010 Posted November 24, 2010 Having a 582, I did a lot of reading (I won't be pretentious and call it research!) on 2 stroke oils. Castrol Activ 2T seemed to be a very popular choice since the demise of Penrite T40 C. I have used it for 30 odd hours but have no objective measure of its quality. I don't normally "put my faith in the market", but I believe that Castrol would have a lot to lose by selling a poor product. By the way, compared with motor bikes I don't think that the 582 is a high performance engine. Just my thoughts. Don G'day Farri, I thought a thorough discussion on 2 stroke oil in http://www.recreationalflying.com/forum/avionics-engines-props-recreational/5970-2-stroke-oil-rotax-what-one.html was pretty exhaustive. I'm settling for Castrol Active 2T in my 582 Cheers, Pud
Ballpoint 246niner Posted November 24, 2010 Posted November 24, 2010 We went through this years ago when Penrite pulled the pin on TS40C- Active 2T is the go- I ran it for 2 years after "green slime" and is a minerally constituted semi synthetic with the associated cooling properties that the 582 likes.
facthunter Posted November 24, 2010 Posted November 24, 2010 Synthetic oils. I agree that the 582 is not a high performance engine as 2 strokes go. Aero engines do however get a fairly hard slog in some aircraft . They operate at about 80% power or above, for a lot of the time. Most other applications aren't as severe. I personally use Valvolene racing 2-stroke as it is a MINERAL based oil, which gives good storage characteristics, if you don't fly everyday.. The LAST thing you need in two-stroke motors is CARBON forming in the ring grooves. This will cause ring breakage and a very sudden cessation of noise. Synthetic blend oils can stand more heat. With an aeroplane it is better to be sure with oils by going a bit further up the scale than chancing it. At 50/1 there is not much there The ordinary 2T is what you would use in a lawnmower as far as I could determine on the Castrol site. Nev
farri Posted November 24, 2010 Author Posted November 24, 2010 G'day Farri,I thought a thorough discussion on 2 stroke oil in http://www.recreationalflying.com/forum/avionics-engines-props-recreational/5970-2-stroke-oil-rotax-what-one.html was pretty exhaustive. I'm settling for Castrol Active 2T in my 582.Thanks Pud,don`t know how but missed that one. Cheers, FRank.
pudestcon Posted November 24, 2010 Posted November 24, 2010 G'day Farri,I thought a thorough discussion on 2 stroke oil in http://www.recreationalflying.com/forum/avionics-engines-props-recreational/5970-2-stroke-oil-rotax-what-one.html was pretty exhaustive. I'm settling for Castrol Active 2T in my 582.Thanks Pud,don`t know how but missed that one. Cheers, FRank. You probably missed it Frank, while you were learning to be so fluent in French Pud
farri Posted November 25, 2010 Author Posted November 25, 2010 Hey Pud,you reckon if I learn Mandarine,I can become Prime Minister for a while? Frank.
pudestcon Posted November 25, 2010 Posted November 25, 2010 Hey Pud,you reckon if I learn Mandarine,I can become Prime Minister for a while? Frank. It will only be for a while Frank, before you get "White Anted" by your 2IC:laugh: Pud
