So you think that flying an RAA aircraft can be a bit of a challenge at times,this is what the crew of the Airbus A380,bound for Sydney,had to deal with, when fluid started flowing out from a wing.
Some of the warnings that sounded:
  • Landing gear control and indicator warnings
  • Multiple brake system messages
  • Wing slats inoperative
  • Multiple fuel system messages, including a fuel jettison fault
  • Left wing pneumatic bleed leaks
  • Avionics system overheat
  • Centre of gravity messages
  • Flight controls – ailerons partial control only
  • Flight controls – reduced spoiler control
  • Autothrust and autoland inoperative
  • Engines No 1 and 4 operating in a degraded mode
  • Flight controls operating in alternate law
  • Hydraulic system – low system pressure and low fluid level
  • Hydraulic system – engine No 4 pump errors
  • Failure of the alternating current (AC) electrical No 1 and 2 bus systems8
  • Engine anti-ice and air data sensor messages
  • No 1 engine generator drive disconnected
Takes Timeto go through the checklists
Indeed it does, and so does dumping fuel to get to a landing weight so you stand a chance of pulling up on the runway. Having one engine that you can't throttle back and NO anti-skid Which means you are guaranteed to blow all the tyres (plus a few other problems)
This effort was a big deal. Nev
The boys earned their salary that day..
I reckon.
Guest davidh10
It was reported in one of the interviews that it took over an hour to deal with all the error messages.
Geez. It took me about an hour just to read all the messages... 006_laugh.gif.0f7b82c13a0ec29502c5fb56c616f069.gif
Nice to see the pilots getting some good press.
