geoffreywh Posted January 17, 2011 Posted January 17, 2011 Anybody know where to get the cruising levels sticker?. I removed mine when renewing the dash, now I can't find a replacement...Thanks. G
Ultralights Posted January 18, 2011 Posted January 18, 2011 cruising levels are pretty easy to remeber, if you live on the east coast, rember its odds and evens +500, well going east its odds, i think of it as, thats odd to be flying out over the pacific... to the east.
mAgNeToDrOp Posted January 18, 2011 Posted January 18, 2011 or "odd bunch in the east" as I was taught ;)
dazza 38 Posted January 18, 2011 Posted January 18, 2011 I just remember one phrase"odd east plus 5" repeat to yourself 20 times and you will never forget it.
Guernsey Posted January 18, 2011 Posted January 18, 2011 I usually visualise the compass direction (clockwise) so the first half O-180 degrees is number one (odd number) and the second half 180-360 is no two (even number). Then just add the extra 500 feet.
geoffreywh Posted January 18, 2011 Author Posted January 18, 2011 Great suggestions all. Bt you're missing the point, I wanted the sticker to cover a small hole made in error
pudestcon Posted January 18, 2011 Posted January 18, 2011 Great suggestions all. Bt you're missing the point, I wanted the sticker to cover a small hole made in error Geoff, Geoff, Geoff:laugh::rofl:You had us all going there... Running off at a tangent I was, thinking about hemispherical rules and such:big_grin: Just chew some gum and shove that in the hole, bit of paint and you'll be apples mate:thumb_up: Cheers, Pud
Guest ozzie Posted January 19, 2011 Posted January 19, 2011 Gee you lot would be great entertainment gathered around the bar.
facthunter Posted January 19, 2011 Posted January 19, 2011 Goeff, just put some clever slogan instead. OR failing that use one of these.ie, gravity NEVER gives up. he who stalleth,falleth etc or "I would have made this aircraft "foolproof' but fools use such ingenuity...... This notice covers a hole I drilled in the wrong place... The others are not so obvious... Nev
Guernsey Posted January 19, 2011 Posted January 19, 2011 I did the same with my Winton Swingwing so I inserted a small red button with a label underneath which said ' Ejector Button'. This was on an overhead panel.
geoffreywh Posted January 20, 2011 Author Posted January 20, 2011 at the risk of being politically incorrect, I have just made a sticker (with the printer) that says "East is Odd" how true that is......problem solved.....and I was thereby reminded of the dislexic agnostic insomniac who used to lay awake at night wondering if there was a dog............G
Guest ozzie Posted January 26, 2011 Posted January 26, 2011 I did the same with my Winton Swingwing so I inserted a small red button with a label underneath which said ' Ejector Button'.This was on an overhead panel. Guernsey, do you have a photo of the Swingwing. i think Col only made a couple of them and not much info around on them. cheers Ozzie
Guernsey Posted January 27, 2011 Posted January 27, 2011 Hi Ozzie, I do have info and photos but will open up a new thread as this one is related to 'stickers'. Alan.
