Turbo_Boss Posted February 26, 2011 Share Posted February 26, 2011 Hello Guys, Here is my problen with my ROTAX 914 Turbo Last weekend, when I was going to take off, I advance the throttle to full and then advance the lever to engage the turbo, I fill when the turbo kick in for a few seconds but then then I fill the engine loose power like if I move the lever back to disengage the turbo. I abort the take off and get back to the hangar. Thinking that the problem was old fuel, I remove completely the fuel, put new fuel, new plugs, clean the air filter, clean carburators, start the engine and everything was OK. Since is was late, I dont fly it. Today I start my engine ROTAX 914 Turbo and during the warn up, around 3 minutes of engine runing at 2,000 RPM, the Ambar Warning TCU light, blink 3 times and then stop blinking. The Engine is installed on a Magni Gyro and it has 248hrs This was my EIS reading when this happened: Fuel Presure: 6.5psi Engine RPM: 2,000 Oil Temp: 95� EGT: 1,000 CHT: 120 I was checking the Rotax 914 Trouble Shoting Manual and its says that if this Ambar TCU warning light blink, its mean that there can be a problem in: Wiring Sensor Sensor damage TCU Failure Air Box Leakage So where you recomend me to start looking for the problem? THX Isaac Link to comment Share on other sites More sharing options...
