25nm from takeoff point. Can be any airfield. Landing at other fields without XC is a hazy area and someone more qualified will be able to clarify that for me. Most schools won't allow you to land at other aerodromes without XC though (just FYI)
-Andrew
Guest Jake.f
Ah ok that is good then. I wouldn't be intending on landing at other airfields just was wondering, it would have been irritating if I had the cert. but the 25nm was only from Coffs...
Check out RA-Aus Ops Manual: Section 2.01-1, 4
It mentions 'not greater than 25 nautical miles from the point of departure unless you have a X-Country endorsement.
It also states that Consecutive flights of 25 NM do not comply with this requirement.
No mention that I can see of a 'home aerodrome' or anything. Once you have a certificate, you can go to another airfield, rent a plane and fly it in the local area...
Guest Jake.f
Exactly!
Money well spent though.
Guest Jake.f
Do they do training or just hire out a/c?
Also I'm assuming no one knows of any RAA schools in Armidale...
Guest davidh10
That is quite good then, I think I'm going to have to try rather hard to get the certificate before uni so I can on the odd occasion jsut go hire an aircraft for a while, I am thinking flying will be the only thing keeping me sane while I spend 7 years doing medicine....
Naaah, You'll fly through it 006_laugh.gif.0f7b82c13a0ec29502c5fb56c616f069.gif
Guest Jake.f
Thanks for that, I suppose I shall see where I end up. I think there is a 95% chance I will be living in Newcastle next year so I shall check them out. I found another school who use Jabiru's and operate out of Cessnock as well...
Saw one of them at the Avalon airshow 2009 looked nice. i have never flown a Jab only tecnams and GA. thanks for your insight.
So are the Pioneer P200 a good aircraft to fly?
I fly a P200 Hawk, which is almost the P300 without the retracts. The one I fly has the Constant speed prop and Rotax 100hp - goes like a rocket!
They're a nice aeroplane, but have a fairly decent price tag unfortunately.
Tractive Prop Motz... so yeah, not really CSU
