Garry Morgan Posted May 20, 2011 Posted May 20, 2011 We are starting a new aircraft this week, it will be a 17m span (6piece wing) the outer pannel will be removable to the size of the sierra to go into the hangar ,of fully derig, Two seat side by side ,80HP Rotax power plant up front ,low wing, polly headral wing, It will be restisered with GFA but can also be with RAA, An all metal aircraft, it will be avaible as plans ,kit or built.It is intended as a touring motor glider, but with a wing loading of 34 solo to 43kg per sq m two up will also have a reasonable glide performace of 25-1 1
