Does anyone know the effect, if any, of the occasional splash of unleaded on Dacron as used for wing covering in several rag and tube designs?
And the most suitable removal/neutraliser
in other words is there something better suited than
soap and water?
many thanks
Davidh
Guest pelorus32
Hi David,
suggest you might contact Bainbridge International in Sydney and ask that question. They supply the sailmaking community with among other things dacrom fabric. They will have seen and heard of every possible contamination I imagine.
Try this for a number (02) 99381788
Regards
Mike
Sailboats use dacron in its natural state but aircraft are finished with paint of some sort to protect from UV rays so try the paint supplier. I used Stitts finish and I believe it is supposed to be resistant to fuel, but it would depend on additives etc. Soap seems to work well and I have a car wax containing carnuba on as added protection, I also only use 100 low Lead.
Thanks Mike,
good suggestion,
with the fuel tanks within the cabin
it is almost inevitable that the occasional
spill occurs.
Davidh
Pro Racing Regulations [Cars] L.1: FUEL BLADDER
L.1.1: MATERIALS
Bladders shall be constructed of nylon, or Dacron, woven fabric, impregnated and coated
with a fuel resistant elastomer
Looking at your avatar, you are spilling neat unleaded onto your sailcloth, if anyone is reading that has a twostroke with sailcloth, a slightly stronger detergent may be required for the oil content in the fuel.
Arthur.
