Guest Stkin0 Posted May 28, 2006 Posted May 28, 2006 SKYFOX GAZELLE CHECKLIST START: Loose articles…………………………………………………………………secure Pax brief……………………………………………………………………..complete Avionics……………………………………………………………………..off Master………………………………………………………………………..on Circuit breakers………………………………………………………………checked Alternator…………………………………………………………………….on Fuel…………………………………………………………………………...on Throttle………………………………………………………………………..set Strobe…………………………………………………………………………on Brakes…………………………………………………………………………on Cdis……………………………………………………………………………both on Choke………………………………………………………………………….as required Prop……………………………………………………………………………clear prop Starter………………………………………………………………………….engaged AFTER START: Rpm…………………………………………………………………………..2000 Oil pres……………………………………………………………………….rising Avionics……………………………………………………………………....on Clear to taxi………………………………………………………………….check brakes TAKE OFF PRE: Cht temp…………………………………………………………………….green Brakes……………………………………………………………………….on Rpm………………………………………………………………………….3800 Oil temp/press……………………………………………………………….checked Voltimeter…………………………………………………………………...checked Cdis………………………………………………………………………….Checked Carb heat……………………………………………………………………. Checked Idle…………………………………………………………………………..1600-1800 Trim………………………………………………………………………….set Throttle friction……………………………………………………………...firm Fuel………………………………………………………………………….on/sufficient Fuel pump……………………………………………………………………on Instruments…………………………………………………………………..check/set Cdis………………………………………………………………………….both Carb heat…………………………………………………………………….cold Controls……………………………………………………………………..full and free Doors……………………………………………………………………closed/locked Oil temp………………………………………………………………...checked Radio call……………………………………………………………….complete LANDING: Breaks………………………………………………………………….off Under carriage…………………………………………………………down Mixture………………………………………………………………..auto Fuel…………………………………………………………………... on/pump/qty Engine int……………………………………………………………...green Switches……………………………………………………………….both cdis Hatches………………………………………………………………..secure Harness………………………………………………………………..secure SHUTDOWN: Trim…………………………………………………………………full back Avionics……………………………………………………………..off Throttle………………………………………………………………closed Cdis………………………………………………………………….check 1&2 Cdis………………………………………………………………….off Master……………………………………………………………….off some parts of this list were added for student pilots so tht they recognise mixture and landing gear and some others (as the gazelle has neither of these the reason for adding this is when i was looking on websites (internet) i couldent find anything about it. so here it is for all of you
barandbrew Posted May 28, 2006 Posted May 28, 2006 Hi Steven You missed one thing Sit Back and enjoy flying one of the best aircraft in Australia !! JOhn
Guest Stkin0 Posted May 28, 2006 Posted May 28, 2006 That's true I did, but any time I go up whether it be for a lesson or just for fun...I enjoy it
