Russ Posted January 24, 2014 Posted January 24, 2014 Ok......what,s this "cold start kit" you mention.
Old Koreelah Posted January 24, 2014 Posted January 24, 2014 Ok......what,s this "cold start kit" you mention. It's a clever replacement for the LH coil, Russ. While the starter is energised the secondary winding cuts in and is triggered by a hall-effect sensor a few degrees after the coil. It produces a retarded spark at very low revs, only when cranking. Just what you need for a cold Jab with crook battery. 1
Keenaviator Posted January 24, 2014 Posted January 24, 2014 It's a clever replacement for the LH coil, Russ. While the starter is energised the secondary winding cuts in and is triggered by a hall-effect sensor a few degrees after the coil. It produces a retarded spark at very low revs, only when cranking. Just what you need for a cold Jab with crook battery. I'll be putting one of these on my UL 450 project as it has an early solid lifter 2200 with a smaller starter motor. The kit should negate any shortcomings of the smaller starter motor. Laurie
