I'm running this idea up the flagpole to see who salutes.
Would you be interested in purchasing an electronic carbon monoxide detector for you plane?
Card type CO detectors cost about $10, and have an maximum life of 18 months from the time they are opened. I am thinking of a device that can be plugged into an aircraft's electrical circuit (both 12 & 24 VDC) perhaps via a similar power outlet that a GPS is connected to. The device would be housed in a box about the size of a cigarette packet (are we still allowed to use "cigarette packet" as an indicator of size) and would have a flashing LED warning light and siren to warn of the presence of dangerous levels of carbon monoxide. I would not be a permanent fixture. You could remove it from your plane and use it in your car or boat.
At this stage, I'm hoping for a purchase price of around $60 - $75.
This device would be used in an enclosed cockpit, so, despite your interest, trike, open cockpit and gyro pilots need not reply:cheezy grin:
Old Man Emu
l would be intrested in one for my skyfox for that price the ones in USA are about $300 to $600.
I purchased one from the online shop here for $150 - works great - velcro attached to the instrument pannel. Gives a readout of the current CO readings, with an alarm. Battery life is longer then 100 hr service.
I change both OAT and CO detecor batteries every 100hr service for <$10 and have relibable indications all the time.
The card inticator was located up on the side pannel at the wing route and whilst not saying that the information was wrong - I never looked at it - only the flight panel whilst flying.
A friend of mine has relocated his current card type detector to the instrument pannel which is at least scanned as a normal instrument scan.
With the actual read out I am happy to use cabin heat [not needed often in NQ] if necessary.
Frank M
Yes, please.
Guest JRMobile
OME
keep the info coming - sounds good
OME, sounds like I need one at that price....:big_grin:
regards
Marcus
Thank you all for your comments. It seems that it is going to be worth my while to do some R&D. I have an electrical engineer who can design the electronics, and I have just located a supplier of some of the hard to find components.
Give me a couple of weeks and I'll hopefully have more information.
Old Man Emu
Thank you all for your comments. It seems that it is going to be worth my while to do some R&D. I have an electrical engineer who can design the electronics, and I have just located a supplier of some of the hard to find components.Give me a couple of weeks and I'll hopefully have more information.
Old Man Emu
That sounds good OME. Perhaps the finished product could be stocked in Ian's shop?
