Guest harwis Posted September 7, 2011 Posted September 7, 2011 Does anybody knows the Jabiru propeller holes pattern? (the diameters of center holes, diameter of bolt holes and the bolt holes pattern on PCD) Thanks Harris:puzzled:
Old Koreelah Posted September 7, 2011 Posted September 7, 2011 Does anybody knows the Jabiru propeller holes pattern? (the diameters of center holes, diameter of bolt holes and the bolt holes pattern on PCD)Thanks Harris:puzzled: I can't help you, but when you get the numbers, ensure it's for the correct engine. I was sent a plate which was too large for my 2.2L, so I presume it was meant for a 3.3L.
Guest harwis Posted September 7, 2011 Posted September 7, 2011 Thank you for your reply. yes you are right, J2200 flange is different from that of J3300, but I can't find out the flange drawing on Jabiru Website. My friend is making a wood propeller for J2200 engine, 60"x42", but don't know the holes information. Harris
Guest harwis Posted September 13, 2011 Posted September 13, 2011 Finally got it. There are [email protected], and [email protected], hope useful for somebody else.
