The DVD states that I should not use automotive crimp lugs but purchase the specific aviation type as they are superior.
Is that the case and if it is who supplies them?
Cheers.........Doug
Hi Doug
Although I haven't put them into the shop here as yet, Rec Flying can supply all your electrical needs such as Aviation Crimp Lugs.
If you like to put together a list of what you need and PM me - make sure you check prices elsewhere first to make sure our supplier and low margin is cheaper for you.
Hope this helps!
Rob
CHT probes and senders I can't get at the moment - I will need to find a supplier first - I presume they would be engine type specific, would they?
