winsor68 Posted September 29, 2011 Posted September 29, 2011 Found this photo on an advert for a nice little single seat aeroplane for sale... Would this be ok? I guess they would be easily replaceable... and cheap!!!
pudestcon Posted September 29, 2011 Posted September 29, 2011 The same principal is used on my Thruster, and other Thrusters I have seen, but with better adaption for security. My tailwheel has a number of loops of shock rubber, the kind you can get at Bunnings, then tensioned up to provide the correct amount of control authority and to stop tailwheel 'shimmy' - reminds me; I still have a bit of that I must sort out. In addition, my tailwheel has a positive but loose linkage made from flying wire material so I still have some control if the shock rubber/bungy cord lets go. I'll see if I can find a photo to post here. To answer your question Win - I reckon I would modify the set up as shown in the photo. Not quite secure enough for me. Pud
winsor68 Posted September 30, 2011 Author Posted September 30, 2011 Thanks... I am not quite in the market yet but it is good to learn about this stuff. The aircraft is a beautiful little machine... the use of the bungees is certainly practical and economical.
Guest ozzie Posted September 30, 2011 Posted September 30, 2011 Right from the start with the early Stolaeros and Condors i found trying to get a decent tail wheel spring set up for steering to be a pain. The final answer was simple. Leave it non steerable just put a friction washer in there for a bit of resistance. Rudder and throttle works ok for me.
