Admin Posted May 28, 2006 Posted May 28, 2006 This is the new panel in the CTsw 2006 version with the options that are available.
Guest micgrace Posted May 28, 2006 Posted May 28, 2006 Hi Ian, should have toebrakes instead of the dirty big brake lever. Impressive otherwise Micgrace
PaulN Posted May 28, 2006 Posted May 28, 2006 I want one!!!! Where's the auto-pilot switch? Does the engine instr panel incl fuel flow, fuel remaining and manifold pressure read outs? I hate those ridiculous plastic sight glasses mounted abovemy head at each wing root in my CT2K. I notice the value of the Euro is getting away on us again ... so how much is the CTSW as shown above now? Michael, you'd be surprised how instinctively the right hand moves from the throttle to the hand operated brake in the CT ... very easy to use and with a positive and easy to operate (with a fick of the thumb) brake lock mechanism to boot. Paul (going greener by the day) PS Anyone out there with qualifications and experience repairing damaged carbon fibre and kevlar construction?
Admin Posted May 28, 2006 Author Posted May 28, 2006 - The auto pilot switch is a white button on the stick just in front of the red PTT button. The Dynon Engine Panel on the right does have manifold pressure and I believe a fuel management system but not actual fuel gauges. Just to upset you more paul here are the new swish high back seats that are an option:
Guest micgrace Posted May 28, 2006 Posted May 28, 2006 Hi Ian, excellent idea the brake set up really, especiallybrake lock.The toe brakes quipisa personal preference thatI got used to ages ago. I wish everything had brake lock make life a bit easier in thos situations that call for it. Micgrace
