Yes guys, Bex's advice is sound! Absolutely rotten luck but time will change how you view this. I sure hope you can find it in your hearts to fix it! John.
  • Replies 186
Sometimes just making a start helps... the number of times I made screw-ups in my aircraft build, (admittedly nowhere as big to repair), I shut the door and left it to rot in the shed.
I mulled and stewed on it for sometimes weeks.. much teeth gnashing and hair pulling!
But once I decided on a course of action, maybe ordered in new materials and then actually picked up the tools to make a start, it all came together and was back on track in no time.
The final inspection was last Monday and am waiting for the paperwork to return from RAAus, over 8 years from starting the Sonex project!
Soooo, where are the pics ?
Gareth and Craig, a wise man once said - never, never, never, never give up.
The pain will pass, then get that kick butt aircraft back in the sky.
Gareth and Craig, a wise man once said - never, never, never, never give up.The pain will pass, then get that kick butt aircraft back in the sky.
Hi Gareth and Craig if I lived up your way I would be trying to muster a group of willing people with building experience to help you put that beautiful aircraft back in the air again. We need that aircraft gracing our skies.
Alan Marriette.
  • 3 months later...
NOOO! As an aspiring LSA pilot that got so enthused by following this build thread, please, please, don't give up! Left as is this is a tragic ending... As other have said, give it some time and recoup.
Chins up and forge on!
  • 5 months later...
As Kevin says its getting there.
The RH wing is 90% rebuilt, just need to do the fairings at the wing/ fuse join, still need to check the internals on the LH wing and modify the nose wheel. I will probably change it back to its original design.
Rob
