Deskpilot Posted April 7, 2012 Posted April 7, 2012 Some time in the past I mentioned the Citroen GSA boxer engine and wondered if it would be suitable for an aircraft. I found that there was indeed, one example where it had been used but couldn't find any info on the plane,, namely the AS-37, designed by a Frenchman named Andre Starck. Well, yesterday I struck gold. I went to a French aviation site and found, not only pictures of the plane, but also a new and intriguing design configuration that is not used today, at least not in this way. It employs what is known as the Knoller-Belz Effect. That is, a constant, wide open slot, between 2, staggered wings that are boxed at the ends. This produces a very wide c.g. travel range which gives STOL and almost stall proof performance. The nearest I can equate today would be the Flying Flea(not Boxed) or maybe the Sunny Boxwing. Both these designs have the close coupled wing set-up. Rather than go into my own interpretation, I'll leave it to you to peruse the following link. For what it's worth, the Citroen engine was a little under powered for such a large aircraft at 65hp so Starck eventually opted for a 100hp Porche engine. This doesn't rule out the use of the Citroen, although it will need a PSU to reduce the 8000rpm the engine is capable off. 4cyl; Citroën GS 1.2; 65hp@5700rpm; 1973-1983; Wt = 220#. Geared to 0.5 and adapted to drive two pusher propellers; this was one of the engines developed for the Citroën GS automobiles; other GS engines of the same configuration had 61.9 cu. in. / 1015 cc, 68.9 / 1129, 79.3 / 1299, and 121.4 / 1990 displacements. Starck, too, found that his aircraft was underpowered with this engine and turned to a converted Porsche engine of 100hp. J78-79toJ82-83; SA7/75, 8/76. Applications: (France) Starck A.S. 37A [F-WYBQ], A.S. 37B [F-WXDU]. http://www.citroenet.org.uk/passenger-cars/michelin/gs/flat-4/engine.html http://www.rexresearch.com/starck/starck.htm The 1st images are of the later, modified plane. Scroll down for the original AS-37.
Deskpilot Posted April 9, 2012 Author Posted April 9, 2012 What...no comments. Surely the configuration deserves some discussion if nothing else.
shags_j Posted April 9, 2012 Posted April 9, 2012 Hey it looks really interesting. I need to read up on it more though (I think I my do an RC airplane with this config and see how it goes). Should probably leave the schwastika off yours though ;)
fly_tornado Posted April 10, 2012 Posted April 10, 2012 What...no comments. Surely the configuration deserves some discussion if nothing else. It is old and french, good if its a bottle of wine but not an engine. Where do you find parts for a 40 y/o engine?
