Guest pookemon
Hey OME!What sort of stuff do you deal with??? I will be needing a heap of sheets, angle,tubeing as well as rivets, bolts ect for my build
Now that OME has said he doesn't deal with metal I'll give Performance Metals in Sydney a plug. I've bought a bit of stuff off them and find them to be great to deal with. I've also dealt with Airport Metals in Tullamarine. They are good to deal with but have a $100 minimum order.
Thanks POOK, I have already emailed performance metals for a quote and will forward it on to Airport metals but, I think freight is going to be killer up here
I don't deal in metal, but I handle all the rest of your hardware needs. I often can reduce the cost of imported parts a little bit as I am min abetter purchasing position than a person buying one-off.
I will send you a pm OME with what i will be needing for a quote
If you are after metals also try H-aircraft spares they are great to deal with.http://www.aviationtrader.com.au/SubsampledImages/AdInstance/04FFCFEE-1.pdf
Gareth:
There is an alternative AS&S supplier at Caboolture. It the beaufort restoration people and they go by the business name of ASAP spares. A warning though, they are very expensive too.
  • 3 weeks later...
