Hi All
Just removed my rudder and found significant wear on the top alum hinge bracket
The middle bracket worn but not as much
No significant wear on the bottom bracket
Anyone else had this problem ????
Hi AllJust removed my rudder and found significant wear on the top alum hinge bracket
I'm not a Savannah owner, but that could indicate that the 3 hinges do not line up, or possibly that the top of the vertical stab flexes mor than the bottom in flight.
Yes I have seen it. What you will find is the hinges have been loose for a long while. What they do is rattle and spin in the aluminum and wear both the brass bush and the aluminum. You should check the aileron hinges as well they can wear fast if they aren't tight. All hinges wear. Keep up with the maintenance. Gundy
RobertHow many hours has it done? Is it worn round or egged?
About 180 hrs Hinges are worn egged
  • 2 months later...
Robert,
I am having trouble with the rudder hinges on my XL not aligning. Do you recall whether your hinges on the rudder were in line.
Bob
Robert,I am having trouble with the rudder hinges on my XL not aligning. Do you recall whether your hinges on the rudder were in line.
Bob
As far as I can recall they were in line with no problems
Bob
180 hours seems way too little time to get serious problems.
I wonder if the short time in service and the alignment issue are related? Alternatively, perhaps Bob's alignment problem is just a one-off??
