RKW Posted June 26, 2012 Posted June 26, 2012 The use of cats as an aid to aviators has been known for many years but don't throw it out of the aeroplane - by all means throw it but keep it inside the "cabin" - cats always land on their feet when thrown so their feet will always point towards the ground - always good to know whuich way the ground is. Interesting theory, and it was apparently used by early aviators who would take a cat with them for that purpose. One aviator even took a lion with him! Early form of instrument flight! Bob
Ballpoint 246niner Posted June 26, 2012 Posted June 26, 2012 WHAT A CAT ASTROPHY. Apparently the aircraft went into some form of Cata- batics:roflmao: 1
Sapphire Posted June 26, 2012 Author Posted June 26, 2012 The use of cats as an aid to aviators has been known for many years but don't throw it out of the aeroplane - by all means throw it but keep it inside the "cabin" - cats always land on their feet when thrown so their feet will always point towards the ground - always good to know whuich way the ground is. Double ditto
motzartmerv Posted June 26, 2012 Posted June 26, 2012 Cats have many uses in science and engineering... Also very useful around the house.. They can be used to untangle headphones with a minimum of fuss.. But combined with a piece of buttered toast can be a free source of perpetual energy. If you tape a piece of buttered toast to the back of a cat, the laws of physics tell us that if you drop the cat upside down, neither the cat nor the toast will ever hot the ground due to cat always trying to land on it's feet and the buttered toast always tending to land buttered side down... The cat/toast machine will just spin forever..;) try it... It works...!!!! 2
motzartmerv Posted June 26, 2012 Posted June 26, 2012 Oh... Suppose a video is worth a thousand briefIngs... So here's how to untangle your headphones using your cat.
Tomo Posted June 26, 2012 Posted June 26, 2012 Good one Motz, wondered how long it will be before you said that!
Sapphire Posted June 27, 2012 Author Posted June 27, 2012 I didn't see him use the headphones after that! While we are on bizarre stuff, I was watching Cops last night and this guy was sitting in an ambulance telling a police officer that he had become pregnant to a dinosaur and wanted to go to the maternity hospital. The officer queried him as to how that happened. Wasn't too sure but somehow the eggs got implanted into him. Wonder what you would call the "kid"; T-rex sounds a bit classy. What does this have to do with flying? Absolutely nothing.
Sapphire Posted June 27, 2012 Author Posted June 27, 2012 Cats have many uses in science and engineering... Also very useful around the house.. They can be used to untangle headphones with a minimum of fuss..But combined with a piece of buttered toast can be a free source of perpetual energy. If you tape a piece of buttered toast to the back of a cat, the laws of physics tell us that if you drop the cat upside down, neither the cat nor the toast will ever hot the ground due to cat always trying to land on it's feet and the buttered toast always tending to land buttered side down... The cat/toast machine will just spin forever..;) try it... It works...!!!! Not on my puddy cat. Sounds interesting but not perpetual. You still have to feed the cat.
turboplanner Posted June 27, 2012 Posted June 27, 2012 My ancestors built windjammers on the Clyde, so knowledge has been passed down from generation to generation. The Captains always had a ship's cat. They were great at plugging leaks. You had to replug the leak in the beginning and your hands bled a lot, but it settled down after a while. 1
Sapphire Posted June 27, 2012 Author Posted June 27, 2012 I think we need a new preflight check!!! I found a loose plug--that's it. Actually a non fuctioning cyl. is interesting. In a v8 it would be hardly noticeable in a car but of course in a single cyl engine it would attract attention. I've driven home [slowly] a few 4 cyl cars working only on one or two cyl What has this got to do with flying? Absolutely everything if it happens to you. 1
eightyknots Posted June 27, 2012 Posted June 27, 2012 Apparently the aircraft went into some form of Cata- batics:roflmao: ....and then they produced the Catalina range of aircraft.....
RKW Posted June 27, 2012 Posted June 27, 2012 ....and then they produced the Catalina range of aircraft..... I was catatonic after watching that!
Guernsey Posted June 27, 2012 Posted June 27, 2012 Actually a non fuctioning cyl. is interesting. In a v8 it would be hardly noticeable in a car but of course in a single cyl engine it would attract attention. I've driven home [slowly] a few 4 cyl cars working only on one or two cyl Happens all the time with Jabirus. Alan.
Sapphire Posted June 29, 2012 Author Posted June 29, 2012 I have another one which is just a simple flat tyre-but a big nusance especially if you are miles from help. I have thought of taking along some canned goop that goes into your tyre and seals up small leaks. But you would have to take the weight of the a/c off the tyre before it will go in. It will fill up the tyre with enough pressure to "get you home". Don't store it in your cockpit in case it thinks you have a flat tyre when you're cruising at 5000'. Hope this keeps the ideas coming in, besides I'd like to see 2000 hits on this thread.
eightyknots Posted June 29, 2012 Posted June 29, 2012 I have another one which is just a simple flat tyre-but a big nusance especially if you are miles from help. I have thought of taking along some canned goop that goes into your tyre and seals up small leaks. But you would have to take the weight of the a/c off the tyre before it will go in. It will fill up the tyre with enough pressure to "get you home".Don't store it in your cockpit in case it thinks you have a flat tyre when you're cruising at 5000'. Hope this keeps the ideas coming in, besides I'd like to see 2000 hits on this thread. Me too: 2000 is a great number to aim for and we're about 5% of the way there. The information so far has been instructive and therefore valuable. Keep it up!!
Sapphire Posted June 29, 2012 Author Posted June 29, 2012 Thanks 80knots. [do you mean 5% to go] This thread has had many posts on what to look out for in that 15 min, or less for a commercial pilot. Also we've heard of a perpetual cat with buttered toast tied to it's back and a guy who claimed to be pregnant to a dinasaur. This would make the old Ed Sullivan show look like a class lesson on the sex life of a guppy.
RKW Posted June 29, 2012 Posted June 29, 2012 I was doing a pre-flight check on the 160 this morning and when I checked the oil, I noticed something partially melted over number one cylinder. Upon removal, it turned out to be a length of clear plastic, not unlike a ribbon of glad wrap. I checked the air intake as well. This is just some of the junk that blows in from the adjacent land fill. Bob
turboplanner Posted June 29, 2012 Posted June 29, 2012 I'm very disappointed in this thread. For a start we haven't had the possum and snake stories........
RKW Posted June 29, 2012 Posted June 29, 2012 That's rubbish, RKW. Nev I stand corrected! :thumb up:You're in fine form tonight, Nev Regards, Bob
RKW Posted June 29, 2012 Posted June 29, 2012 I'm very disappointed in this thread.For a start we haven't had the possum and snake stories........ Ok Turbo, How about the bloke up in Dawin who just lifted off whe a snake came out of the instrument panel! I think it was earlier this year. He returned to Darwin safely, but the snake was never seen again. You wouldn't want to fly that plane again! Bob PS. We should all reach in behind the instrument panel and check for snakes as part of ou pre-flight!?
dazza 38 Posted June 29, 2012 Posted June 29, 2012 I'm very disappointed in this thread.For a start we haven't had the possum and snake stories........ We had a Jet Ranger land at Boonah after complaining of a over temp indication. Dead Snake was found in the engine bay.
dazza 38 Posted June 29, 2012 Posted June 29, 2012 I have also found a fair few defects on aircraft over the years.Too many to mention.
M61A1 Posted June 29, 2012 Posted June 29, 2012 We had a Jet Ranger land at Boonah after complaining of a over temp indication. Dead Snake was found in the engine bay. Where was the snake in the engine bay? and what was over temp? I dunno if civvy ones are different but ours only have gauges for engine oil temp, transmission oil temp and TOT . I've just been trying to figure out how a snake in the engine bay could cause any of these to overtemp.
