geoffreywh Posted May 4, 2013 Author Posted May 4, 2013 Quote "Clearly this engine needs highly regulated fuel distribution to run well and cleanly." ( Ref: needed?) I can't really find where this fact comes from other than it is a valid statement for all engines to run at peak efficiency. I'd agree with the 95hp at 75% though. Time will tell all............
facthunter Posted May 4, 2013 Posted May 4, 2013 In it's own advertising stuff it used the injection feature as overcoming some/most of the shortcomings of previous SV designs such as heating, fuel economy and carbon formation. Nev
Gentreau Posted May 4, 2013 Posted May 4, 2013 One thing that is sure about D-Motor is the excellent level of service they give. A guy at our club bought one of the early 4 cylinder engines, which produced 80hp. It ran beautifully and he really liked it. It started first time every time using an 800g battery and he had about 50 hours trouble free flying with it. However, that orignal design has now been superseded by the improved LF26. Two days ago a guy from D-Motor drove down from Belgium (8 hours) with a replacement engine which he helped our guy install as a replacement on his Sherwood Ranger. The engine tests were completed yesterday and he now has the new version (93hp). What did that cost our guy; nada, nothing, not a cent ! 4 2
ozbear Posted May 14, 2013 Posted May 14, 2013 Here's a question will a dirty battery terminal,a tripped circuit breaker or a blown fuse stop this engine?
turboplanner Posted May 14, 2013 Posted May 14, 2013 Quote One thing that is sure about D-Motor is the excellent level of service they give.A guy at our club bought one of the early 4 cylinder engines, which produced 80hp. It ran beautifully and he really liked it. It started first time every time using an 800g battery and he had about 50 hours trouble free flying with it. However, that orignal design has now been superseded by the improved LF26. Two days ago a guy from D-Motor drove down from Belgium (8 hours) with a replacement engine which he helped our guy install as a replacement on his Sherwood Ranger. The engine tests were completed yesterday and he now has the new version (93hp). What did that cost our guy; nada, nothing, not a cent ! So, even though the existing engine was fine, for no other reason than they wanted to, they gave him a new engine?
Gentreau Posted May 14, 2013 Posted May 14, 2013 Quote So, even though the existing engine was fine, for no other reason than they wanted to, they gave him a new engine? I understand their reason was to have only one version of the engine out in the wild. See their Installations page here: http://www.d-motor.eu/nl/installations-5.htm . 1
turboplanner Posted May 14, 2013 Posted May 14, 2013 Ah, I see - that IS smart marketing - the customer is not saddled with any potential problems on the prototype, plus there are cost savings in not having to maintain a parts inventory for one engine. Great service as you say!
Gentreau Posted May 14, 2013 Posted May 14, 2013 I must say that having spoken to the guy from the company, they certainly seem to be very serious about 'doing it right'. Another example he gave me is that the ECU is fully programmable (I watched him setup the idle on the Sherwood Ranger using his PC plugged into the ECU) and you get the software with the engine to allow you to log data and monitor conditions. If later you have a problem and you contact their telephone support service, and they determine that it requires modifying the ECU, they will give you an access code which is valid for 24hrs only to allow you to make the necessary changes, following their guidance. .
geoffreywh Posted May 14, 2013 Author Posted May 14, 2013 Quote "Here's a question will a dirty battery terminal,a tripped circuit breaker or a blown fuse stop this engine?" Good question..... I think you'll find that the Ign/Injection will have its own dedicated back up battery. The ECU will certainly have a " limp home mode" .With the weight of a LIFE04 battery these days I would expect at least 2 hours flight time after generator and main battery failure.... I don't think the ignition is self generating ala Rotax..........Which is a pity.
fly_tornado Posted May 14, 2013 Posted May 14, 2013 Quote Here's a question will a dirty battery terminal,a tripped circuit breaker or a blown fuse stop this engine? The Achilles heel of all FI engines, the fuel pumps. 1 1
geoffreywh Posted May 15, 2013 Author Posted May 15, 2013 two pumps each with its own power source. I don't think so. My crummy Mitsubishi has run now for 11 years with nary a miss....And don't give me any bull about 75% power. The pump doesn't care.. Although if they were direct injection pumps that might be another story. I fly around on two mags...Both 50 plus years old... I like the odds on the pumps lasting longer
ozbear Posted May 15, 2013 Posted May 15, 2013 I think with the redundent EFI system it would be possible to run 2 totally independent systems with a backup power supply the modern jet liners have a drop down prop driven turbine that takes over flight necessary functions in the event of complete power failure.or as Geoff says a small secondary battery.
fly_tornado Posted May 15, 2013 Posted May 15, 2013 The fuel pumps on your carburettor engine are only doing 2-4psi, the FI engines are typically @ 50PSI. The pumps chew a lot of power, much more than the ECU does. The other problem is the fuel lines, if they start leaking fuel comes out under a lot of pressure (instant fireball). Its a fair trade off as electronics and batteries these days are super reliable.
Gentreau Posted May 15, 2013 Posted May 15, 2013 I think I know the answer, but would rather be sure so I will ask these questions of the owner of the Sherwood Ranger when I see him at the weekend. I'll get back to you..... .
Gentreau Posted May 15, 2013 Posted May 15, 2013 Quote The Achilles heel of all FI engines, the fuel pumps. Here's a thought. Which is more likely to occur, failure of two independant fuel pumps or carb icing ? .
fly_tornado Posted May 15, 2013 Posted May 15, 2013 carb ice. but the electrical needs of those pumps can't be ignored
facthunter Posted May 15, 2013 Posted May 15, 2013 Carb ice is not hard to handle, if you have an adequate system. The intake of any engine can be affected by icing even if only Rhyme (sp)? You have to have some kind of air filter (which could be bypassed). The main fault of a carburetter is uneven distribution of fuel mixture, in some engines.. Nev 1
paulh Posted May 15, 2013 Posted May 15, 2013 Quote Carb ice is not hard to handle, if you have an adequate system. The intake of any engine can be affected by icing even if only Rhyme (sp)? You have to have some kind of air filter (which could be bypassed). The main fault of a carburetter is uneven distribution of fuel mixture, in some engines.. Nev Usually spelt Rime apparently but a bit like other weird words like "girt" by sea 1. A coating of ice, as on grass and trees, formed when extremely cold water droplets freeze almost instantly on a cold surface.
M61A1 Posted May 15, 2013 Posted May 15, 2013 Quote I think with the redundent EFI system it would be possible to run 2 totally independent systems with a backup power supply the modern jet liners have a drop down prop driven turbine that takes over flight necessary functions in the event of complete power failure.or as Geoff says a small secondary battery. The specs on the engine show an integrated alternator, the whole system doesn't appear much different in concept to the average modern gas turbine. Meaning that while the engine is turning, it's generating it's own power to supply it's engine management. I don't really understand why the same people that will tell you a carburettor and magneto is more reliable, will happily get on something with a CFM-56 powering it, with all the FADEC stuff (not bagging CFM in any way). We're just moving into the 21st century, that's all.Note. While I can't speak for this lot, most aviation electronic engine management systems have double redundancy built (and a built in test) into the box itself, just because you can't see 2 boxes, doesn't mean there is no backup. 5
ozbear Posted May 15, 2013 Posted May 15, 2013 Quote The specs on the engine show an integrated alternator, the whole system doesn't appear much different in concept to the average modern gas turbine. Meaning that while the engine is turning, it's generating it's own power to supply it's engine management. I don't really understand why the same people that will tell you a carburettor and magneto is more reliable, will happily get on something with a CFM-56 powering it, with all the FADEC stuff (not bagging CFM in any way). We're just moving into the 21st century, that's all.Note. While I can't speak for this lot, most aviation electronic engine management systems have double redundancy built (and a built in test) into the box itself, just because you can't see 2 boxes, doesn't mean there is no backup. I agree otherwise we would all be still flying around in wright flyers .Thats why a lot of us are flying around in aircraft called experimental without people asking questions and exploring possibilities nothing changes.I think innovators like the guys that start from scratch and build new motors with cutting edge technology need to be encouraged .I asked if the engine would stop if a fuse blows or a battery terminal is loose or a circuit breaker drops out how have they solved these problems .
facthunter Posted May 15, 2013 Posted May 15, 2013 The alternator on a jet engine does not usually supply it's own engine management . It's a main power supply for the entire aircraft electrical system. ( One of three, minimum) and can go faulty (over/undervolt, over /underspeed) and be disconnected in flight, with out affecting anything except electrical total load considerations. There are many electric subsystems that enable isolation for fault checking and limited operation with faullts, as well as a priority supply bus usually denoted "essential". The ultimate supply is from the batteries which is all you might have when you hop into the cockpit. You don't really have aircraft power of any significance, unless external supply available or the APU is running. The type of alternators are AC and have strict limits on frequency so have special constant speed drives to keep frequency in the range required over a wide range of engine RPM. DC supply comes from battery or inverters. Nev
M61A1 Posted May 16, 2013 Posted May 16, 2013 Quote The alternator on a jet engine does not usually supply it's own engine management . It's a main power supply for the entire aircraft electrical system. ( One of three, minimum) and can go faulty (over/undervolt, over /underspeed) and be disconnected in flight, with out affecting anything except electrical total load considerations. There are many electric subsystems that enable isolation for fault checking and limited operation with faullts, as well as a priority supply bus usually denoted "essential". The ultimate supply is from the batteries which is all you might have when you hop into the cockpit. You don't really have aircraft power of any significance, unless external supply available or the APU is running.The type of alternators are AC and have strict limits on frequency so have special constant speed drives to keep frequency in the range required over a wide range of engine RPM. DC supply comes from battery or inverters. Nev The gas turbines I've worked on usually have 2 alternators (each), one is for main power supply, the other, for example in the GE T700 is built into the mechanical fuel pump and does indeed provide the power to run the ecu, the engine is capable of running without external power. This is quite common in later model gas turbines. 1
facthunter Posted May 16, 2013 Posted May 16, 2013 But you can't manage them. All the automatic control systems are from other electrical circuits. Anyhow the main point I would make is that the technology isn't simply a matter of going modern. It's a matter of having something appropriate to the environment it works in and that most operators can deal with and troubleshoot. The newer complex engines will be rectified by "remove and ship to service agent". for adjustments and repair, if we don't watch it. Nev 1
M61A1 Posted May 16, 2013 Posted May 16, 2013 I agree in regard to no user serviceable components, but there seems to a trend of users not servicing their aircraft (other than operating level maint), and having someone else do it. My initial point was that there may well be a higher level of redundancy in what they have, although it's not necessarily visible. 1
