Thruster87 Posted August 30, 2012 Posted August 30, 2012 What is the Correct orientation of the slide on a Bing 94 ? Cheers
brilin_air Posted August 30, 2012 Posted August 30, 2012 Quote What is the Correct orientation of the slide on a Bing 94 ? Cheers Thruster. The holes in the slide go to the back closest to the butterfly. You can check to see if it works by using an airblower and blowing through the carby, it should lift the slide. Brian
Thruster87 Posted August 30, 2012 Author Posted August 30, 2012 Thank you for your reply.That's the way I put it back just wanted to make sure and blowing air made the slide lift up. Also used a bit of dry moly lude on the internal shaft. Cheers
