geoffreywh Posted September 11, 2012 Posted September 11, 2012 I think That I misinterpreted the entire message
Hongie Posted September 11, 2012 Posted September 11, 2012 Reckon it does if it's more then 15 years old I think it said ? Or the control cables are known to be more then 15 years old... Or not known to be LESS then 15 years old
aj_richo Posted September 11, 2012 Posted September 11, 2012 Only affects fttings that scew into a turnbuckle barrel... not your thimble swages, might eliminate a lot of aircraft you are concerned about. However always pays to check any fitting before flight! All other aircraft at the 100 hourly or annually, which should be done anyway if you're on top of your maintenance
geoffreywh Posted September 12, 2012 Author Posted September 12, 2012 I think that I have got the message wrong
aj_richo Posted September 12, 2012 Posted September 12, 2012 Whats it going to be, the CASA version or the RAAus version? You quoted the RAAus to begin with http://www.raa.asn.au/documents/airworthiness/SB-002-15-08-2012-All-Aircraft-Control Cables.pdf PS I understood a terminal fitting to different to a thimble fitting
Guest Maj Millard Posted September 12, 2012 Posted September 12, 2012 It would be nice if they could be more specific about the particular cable in the photos IE: make aircraft ? local product or import ?...was the cable factory produced or other ?...........................................Maj...
geoffreywh Posted September 14, 2012 Author Posted September 14, 2012 I think I got the message wrong
Old Koreelah Posted September 16, 2012 Posted September 16, 2012 Can anyone suggest a reliable and simple way I can test whether my own control cables are stainless, and included in this edict? Home-made cables won't be stamped. I have one manufactured SS push-pull cable, but the others are swaged.
eightyknots Posted September 17, 2012 Posted September 17, 2012 a magnet will tell you....well, it wont actually tell you, but it will show you. The grade of "stainless" used is almost non magnetic. It's the swages they are also worried about! ...as it will on copper cables
