Admin Posted October 2, 2012 Posted October 2, 2012 They got 14 choppers going now Could be why the Dornier is so high
ave8rr Posted October 2, 2012 Posted October 2, 2012 MM I think, going by reports, he was well and truly in the whiteroom for a while... lost in non VMC.... and they had a short duration EPIRB activation they are obviously focusing on that being best estimation on last location. Has it been stated by authorities that it was in fact an EPIRB received momentarily. Why no fix on this beacon by the Satelite? I am thinking that ATC MAY have received a transponder squawk 7700 (ICAO emergency code) as it was about this time that the pilot was trying to establish comms with BNE Centre and was lost on a frequency change. Cheers
rdarby Posted October 2, 2012 Posted October 2, 2012 14? You would only use so many if you needed to cover a wide area and were not sure of where to look. Where would they get that many? This feels very close to home, we all knew that Dragon, and flew in the area it flew in, and I flew in the same weather earlier in the weekend and got on the ground in the sunniest area I was able to. I really hope all works well.
jcamp Posted October 2, 2012 Posted October 2, 2012 Why no fix on this beacon by the Satelite? 406 transmits who immeadiately then every 50 seconds. If GPS then who and where after GPS has a fix (few minutes). If no GPS then 406 fix to a few km after a few satellite passes (hours). A weak 121.5 signal is transmitted for homing with all the problems of homing in a hilly forested area. If single transmission then not much to go on.
Admin Posted October 2, 2012 Posted October 2, 2012 The Kannad PLBs in the Recreational Flying Shop will transmit for 24hrs which I thought was a requirement of PLBs. Naturally an enormous amount of impact or fire will prevent them from working for that 24hr period...or in water...that's why I like the Kannads as they will continue to transmit in water as they float vertically on their own. I would guess that fire damaged terrain would have been spotted by now. It is all taking far too long however there is always hope...and that's what I am doing!
ave8rr Posted October 2, 2012 Posted October 2, 2012 406 transmits who immeadiately then every 50 seconds. If GPS then who and where after GPS has a fix (few minutes). If no GPS then 406 fix to a few km after a few satellite passes (hours). A weak 121.5 signal is transmitted for homing with all the problems of homing in a hilly forested area. If single transmission then not much to go on. Thanks JC. I was aware of GPS / Non GPS. I was just trying to establish if anyone has heard WHAT type of beacon and/or ATC transponder was heard and as you stated may have been a small squirt on 121.5. I know what it is like chasing 121.5 over land. I was a Nav on P3 Orions (5500hrs) and we were often tasked with trying to locate this type of beacon. Over water was much easier. Cheers
Bandit12 Posted October 2, 2012 Posted October 2, 2012 Backing up what Andy said about SPOT - I've had one for several years and think it is fantastic. Someone at home can sit and watch your track every two minutes, and the emergency function will work just about anywhere in the world.....I watched a friend ride around the USA for a week and could track him at any time of the day. Fantastic safety device. 1
AV8A Posted October 2, 2012 Posted October 2, 2012 Just an idea. Assuming one or serveral passengers had mobile phones - its unlikely they were turned off for a short hop. Why not try and see if any of these are hitting local towers and possibly be triagulated?
cscotthendry Posted October 2, 2012 Posted October 2, 2012 Just an idea. Assuming one or serveral passengers had mobile phones - its unlikely they were turned off for a short hop. Why not try and see if any of these are hitting local towers and possibly be triagulated? Good idea and AMSA are all over that. 1
derekliston Posted October 2, 2012 Posted October 2, 2012 Does anyone know of a report on CH 10 news about a missing aircraft from kilcoy Only know of the DH Dragon from Caboolture, long overdue but not yet found.
Mick Posted October 2, 2012 Posted October 2, 2012 Has it been stated by authorities that it was in fact an EPIRB received momentarily. Why no fix on this beacon by the Satelite? I am thinking that ATC MAY have received a transponder squawk 7700 (ICAO emergency code) as it was about this time that the pilot was trying to establish comms with BNE Centre and was lost on a frequency change.Cheers Channel 7 news showed an interview with someone from the rescue operation. They said it was a personal type EPIRB that they received a short signal from.
Kyle Communications Posted October 2, 2012 Author Posted October 2, 2012 does anyone have the search and rescue radio frequencies they use?....I have been scanning the bands but can't find anything. heard the choppers using Kenilworth show grounds as a staging and refueling base on the local Ctaf 126.700 but thats all
Hongie Posted October 2, 2012 Posted October 2, 2012 Yeah, I have been scouring the atc recordings trying to find the mayday call and such but no luck.
Willborne Posted October 2, 2012 Posted October 2, 2012 Just an idea. Assuming one or serveral passengers had mobile phones - its unlikely they were turned off for a short hop. Why not try and see if any of these are hitting local towers and possibly be triagulated? Next to no mobile phone reception over much of the search area. We have a farm based right under the search area south west of Gympie near the Muster site. Mostly native and hoop pine plantation country with cleared valleys in places. We don't live there presently however many of our neighbours have been out searching forestry tracks by vehicle and horseback. Willborne. 1
Hongie Posted October 2, 2012 Posted October 2, 2012 i think this is the area around where the Gympie Music Muster is held? Pretty rugged country for aircraft
AV8A Posted October 2, 2012 Posted October 2, 2012 Next to no mobile phone reception over much of the search area. We have a farm based right under the search area south west of Gympie near the Muster site. Mostly native and hoop pine plantation country with cleared valleys in places. We don't live there presently however many of our neighbours have been out searching forestry tracks by vehicle and horseback.Willborne. Bugger. In saying that - surely a mobile repeater could be flown over the search area and see if something pings it. I was trailbike riding at Kia Ora the weekend before last - Telstra coverage was good to the north east of Gympie.
winsor68 Posted October 2, 2012 Posted October 2, 2012 I would guess that they will have done all of this? Those Dorniers look a bit like pickle sticks with equipment sticking out... Let alone the Search and Rescue Choppers.
Akromaster Posted October 2, 2012 Posted October 2, 2012 Long shot but would any of the passengers or crew have an iPhone with "Find My iPhone" enabled? Ak Edit: unfortunately it does require Internet connection.
Compulsion Posted October 2, 2012 Posted October 2, 2012 Channel 7 just said they are not holding out much hope now. God please don't let that be true. What a tragedy.
XP503 Posted October 2, 2012 Posted October 2, 2012 We need a modern day Bernard O'reilly, I am hoping they are at least alive with the wreck,,,,,,,,,,,gotta hold onto that hope ey 2
Spriteah Posted October 2, 2012 Posted October 2, 2012 Still hoping for the best. Hope this plane and crew, passengers found quickly safe and well.
Guest Maj Millard Posted October 2, 2012 Posted October 2, 2012 The Dragon Rapide just fitted in so well at Monto, cruising around overhead, giving rides all day. Just a massive loss for our sport, which those folks were more than happy to support with their attendance, and for the aviation scene in Australia generally. Our thoughts and hopes are still there for our six aviation enthusist friends.......................
J170 Owner Posted October 2, 2012 Posted October 2, 2012 I may be wrong but the Dragon was used by the RFDS until quite recently, 1970s?
winsor68 Posted October 2, 2012 Posted October 2, 2012 I may be wrong but the Dragon was used by the RFDS until quite recently, 1970s? You may be thinking of the tri-gypsy engined Drover... Surely the Rapide was not in commercial service in the 70's?
