Gentreau Posted November 8, 2012 Posted November 8, 2012 Quote Motor Type Max Power HP Weight KG Jabiru 2200 80 62.8 UL260i 97 72.3 UL260iS 107 72.3 UL260iF 100 72.3 UL350i 118 78.4 UL350iS 130 78.4 Jabiru 3300 120 83.5 Another alternative engine to consider is the D-Motor from Belgium. 93HP four stroke, same weight as a Rotax 582, TBO 1500 hrs, no gearbox, direct drive. http://d-motor1.vpweb.be/Price---product-specifications.html .
Gentreau Posted November 8, 2012 Posted November 8, 2012 Quote When you take into account the extra maintenance costs associated with the Jabiru the Rotax doesn't work out to be that much more expensive. ...... I have no opinion either way regarding Jabiru motors as I have no persoanl experience, however it does seem that they need mor frequent maintenance than the Rotax equivalents and anyone using their aircraft for commecrcial purposes will also need to factor in the cost of the associated downtime. I wonder what that does to the operating margins?
eightyknots Posted November 8, 2012 Posted November 8, 2012 Quote I am also happy to compile this info for everyone to see without an biased opinion. After all that is what this forum is supposed to be about. Using the vast knowledge and experience of all here so that we can all make our own decissions rather than have to read all the negative critism that always seems to find its way here. Safe Flying JabSP6 I hope it keeps that way!
Herm Posted November 8, 2012 Posted November 8, 2012 Quote I get that Team Jabiru don't like my participation on these threads, how have these threads actually helped you? Don't they just reinforce your belief that Jabiru are safe and economical alternative to Rotax? These threads help with solutions to problems. They also help to identify problems in both planes ane people
Yenn Posted November 9, 2012 Posted November 9, 2012 I wonder how many Jab engines are flying in the USA. I regularly check a few web sites on US flying and while people talk about the jab engine I havn't seen any bad reports. there is at least one aircraft type flying in the US with a Jab engine and the manufacturer changed from Rotax to Jab, for reasons unknown to me. 1
bones Posted November 9, 2012 Posted November 9, 2012 Quote I have no opinion either way regarding Jabiru motors as I have no persoanl experience, however it does seem that they need mor frequent maintenance than the Rotax equivalents and anyone using their aircraft for commecrcial purposes will also need to factor in the cost of the associated downtime.I wonder what that does to the operating margins? There is a beauty little J120 here in Charters Towers, was talking to the owner the other week about this subject, and his eyes lit up, then proceeded to tell me in the 200+ hrs he has done in it since new, it has cost him(averaged out) $450 per hr on the motor, now that is about half the cost of rotax right there. to say he is p*ssed was an understatment.
Keenaviator Posted November 9, 2012 Posted November 9, 2012 Interesting maths. 200 hours at $450 per hour is $90,000. Are you sure about this statement?
Gentreau Posted November 9, 2012 Posted November 9, 2012 Certified ? For an RA aircraft ? Do you mean that you have to buy the certified version of the 912/912S ? .
eightyknots Posted November 10, 2012 Posted November 10, 2012 Quote Interesting maths. 200 hours at $450 per hour is $90,000. Are you sure about this statement? I checked the maths with my electronic number box and it gave the answer $90,000. The calculation seems to be OK. 1
bones Posted November 10, 2012 Posted November 10, 2012 Quote Interesting maths. 200 hours at $450 per hour is $90,000. Are you sure about this statement? Yeah sorry typo, ment to be $45.00, 9k, the last little bit cost him near 5 k in one hit. actually i wish it was $450, i could be doing all his work and be happy 1
JabSP6 Posted November 12, 2012 Posted November 12, 2012 Dazza I have done a bit more research into the UL prices and even rang the Aussie Dealer (Les Elliott) The UL350is comes in at $21400. Then Les said you need the accessories kit $2000. GST has to be paid $2340 Freight to Aus he said is around $1700 So this motor adds up to around $27440 here is Aus. Then you need to sort out a Motor Mount as the 2200 motor mount he believe is not suitable. The UL260is comes in at $17200 Total including accessories, GST and Freight is $22820 here is Aus. I hope this helps. Safe Flying JabSP6 2
planesmaker Posted November 12, 2012 Posted November 12, 2012 I can say that a J230 with a 912S if fitted with C/S prop will perform well, at least as well as a Jab3300 engine.In my opinion a very viable alternative if someone wants to develop a STC for it. Tom
facthunter Posted November 13, 2012 Posted November 13, 2012 The availability of a lot of prop choices is an advantage with the 912 's. there is no doubt that the Jab 6 does put out the power claimed.. There are some prop options with it too..Nev
ave8rr Posted November 13, 2012 Posted November 13, 2012 Quote The availability of a lot of prop choices is an advantage with the 912 's. there is no doubt that the Jab 6 does put out the power claimed.. There are some prop options with it too..Nev Hi Nev, are three blade props able to be fitted to the Jab 3300 engine? I was of the understanding that Jab recommended all their engines should be used with wooden two blade units. I certainly have seen three blade units on some 19 registered aircraft with Jab engines. Cheers
facthunter Posted November 13, 2012 Posted November 13, 2012 I agree with you. the safest bet is a wooden two blade for Jab engines. There might be a bit more latitude with the six. I have flown one with CSU amd it was quick but for safety stick to wood. Nev 1
Yenn Posted November 13, 2012 Posted November 13, 2012 Thjose engine prices are scary. I bought a factory new Lycoming O 320 for less than that. and it is 160hp.
Fatman1238 Posted November 13, 2012 Posted November 13, 2012 Quote I can say that a J230 with a 912S if fitted with C/S prop will perform well, at least as well as a Jab3300 engine.In my opinion a very viable alternative if someone wants to develop a STC for it. Tom In flight adjustable prop you mean, can't fit a constant speed to any of our engines unless they are lycomings or continentals.
facthunter Posted November 13, 2012 Posted November 13, 2012 I don't think that is the case. Not all Lyc's and Cont's have oil available to servo the prop and electrically controlled (slip ring etc) are available. The hollow drive on the 912's is helpful. Nev 1
ave8rr Posted November 13, 2012 Posted November 13, 2012 Quote In flight adjustable prop you mean, can't fit a constant speed to any of our engines unless they are lycomings or continentals. I think the Airmaster prop from NZ is constant speed. http://www.airmasterpropellers.com/
Steve Donald Posted November 13, 2012 Posted November 13, 2012 Quote The U/L (and other European motors suitable D-Motor, Metalwork etc) would need to be certified before even an STC mod could be considered.Does anyone know if the importers/factories of any are considering Australian certification? the D-MOTOR Is a direct fit for the 2200Jab about 16500k to Auz side valve and puts out nearly 100hp @ 3200rpm now same weight nearly slightly lighter fitted, 2000hr TBO fuel injected smooth as safer with side valve if you get a failure fly on 3 without any risk ,has certification in Europe certification data is ok for all the overseas Airframes so why would engines be any different, this engine looks good and is a real contender for the 85 to 100hp needs even the Jab 6 power to weight and tourge output is broad and higher max hp comes on early and remains flat typical sidevalve love low revs which is ideal sorry about typos
geoffreywh Posted November 15, 2012 Posted November 15, 2012 I think you are forgetting the Viking/Honda motor, something like $17000? landed (someone correct me please) Now called the Viking 110 alluding to the hp I believe. 100 now engines delivered. Haven't heard of any failures, yet....Looks just great if you can forgive Jan Eggenfella his previous mistakes?....Weights just spot on for the J230....who will be first?......
fly_tornado Posted November 15, 2012 Posted November 15, 2012 eggenfella uses his customer base to test his products. maybe wait until a few engines have made the 1000 hour mark
Guernsey Posted November 15, 2012 Posted November 15, 2012 Quote I think you are forgetting the Viking/Honda motor, something like $17000? landed (someone correct me please) Now called the Viking 110 alluding to the hp I believe. 100 now engines delivered. Haven't heard of any failures, yet....Looks just great if you can forgive Jan Eggenfella his previous mistakes?....Weights just spot on for the J230....who will be first?...... Sloper, on this forum, is fitting one to a Morgan Sierra he is building. Alan.
planesmaker Posted November 15, 2012 Posted November 15, 2012 Fatman, C/S props are definitely available for rotax. I have one fitted on my 914, set the revs you want then use Manifold pressure for power setting. it will maintain the revs no matter what you do (climb, descend etc.) Tom 1
