Tomo Posted October 14, 2012 Posted October 14, 2012 Hey there knowledgable folk, my EGT gauge on my plane has lost a bank, as in, one side is no longer working... I don't believe it's the probe as I pulled them out of the manifold and they look good. And it's not the cylinder, 'cause I swapped them around and both are reading exactly the same, which is nice to know. However... it would be nice to be able to see that on the gauge so is there a way to check the gauge it self or do I have to get another one? Anyone fixed these before... or am I barking up the wrong tree? It was working but stopped about 15hrs ago... Here's a dodgy photo so show you what I mean by one side not working
XP503 Posted October 14, 2012 Posted October 14, 2012 Yea mine did that on the Drifter too when I bought it!!!! I got Richard Eaccott to look at it and he fixed it somehow, he could probably tell you over the phone - call him on 0428 632 476 Really nice guy, knows ''everything'' about Rotax's - However wont ever answer his phone if he's playing golf and I have a feeling he plays on sundays hahah! Give him a try though I bet he will be able to help ya
FlyingVizsla Posted October 14, 2012 Posted October 14, 2012 Hi Tomo, The better half says it is most likely the connection on the back of the gauge - check it is firmly in place. He uses switch grease (silicon) on the connections. We had a similar problem. Sue
Tomo Posted October 14, 2012 Author Posted October 14, 2012 Thanks guys!! Pulled the connectors off again (I had done it before) and cleaned them all up properly and put some of that electrical grease on it and blow me down it now works! Now I just have to re-tune my carby so it runs a bit smoother, and all is well with the world!
Guest Andys@coffs Posted October 14, 2012 Posted October 14, 2012 Thermocouples only generate small voltages and the meter is in fact a voltmeter. It only takes a slighty crappy connection and they will not read.......I suspect that this wont be the last time you do that Tomo Andy
rankamateur Posted October 14, 2012 Posted October 14, 2012 Thanks guys!!Pulled the connectors off again (I had done it before) and cleaned them all up properly and put some of that electrical grease on it and blow me down it now works! Now I just have to re-tune my carby so it runs a bit smoother, and all is well with the world! You are young and airbourne, all IS good in the world what ever your EGT gauge says.
Guernsey Posted October 15, 2012 Posted October 15, 2012 Thanks guys!!Pulled the connectors off again (I had done it before) and cleaned them all up properly and put some of that electrical grease on it and blow me down it now works! Now I just have to re-tune my carby so it runs a bit smoother, and all is well with the world! Replace the connectors with right angle ones (known as 'elbow connectors' ) then you apply 'elbow grease' which is cheaper. Alan.
