Teckair Posted December 21, 2012 Posted December 21, 2012 Wow never thought I would see a Quicksilver do that and did not know they made one capable of doing that, you would want to double check your seat belt on that one!!!
facthunter Posted December 21, 2012 Posted December 21, 2012 I would have thought it might be a bit draggy. That kind of plane loses speed quickly as soon as you start pulling the nose up and start to go vertical unless it has quite a bit of power. Nev
Sapphire Posted December 21, 2012 Posted December 21, 2012 It looks like he is flying below 1000 feet which would support the "crazy" theory. The rest seems ok.
pylon500 Posted December 25, 2012 Posted December 25, 2012 Some clues when looking at the aircraft, no dihedral and a lot of camber on lower wing battens, to give a semi symmetrical section. Hope he has a STRONG kingpost!
503 Posted December 25, 2012 Posted December 25, 2012 Must have been his first time,got it together in the end though!
Pilot in the making Posted September 17, 2013 Posted September 17, 2013 Flyerme this is an amazing video! My Dad flies drifter ultralights and is currently building an aerobatic aircraft, I mentioned this video to him and he wants to know some information about this plane if possible? If I can send you a private message with his details in it that would be amazing! 1
David Isaac Posted September 17, 2013 Posted September 17, 2013 Wouldn't really matter how good it was. As long as it has numbes on the siude it is illegal. Register it VH experimental and go through the process and its legal. Two strokes make great aerobatic engines as you can see. Wayne Fishers VH experimental Drifter was two stroke powered.
Guest Maj Millard Posted September 17, 2013 Posted September 17, 2013 I have quite a bit of time in the Eipper MXL, they are hoot to fly, and a blast to land, with ones posterior only inches off the deck. They have a nice side mounted (rh) control stick, and were very responsive. I did see one two seat tandem model that was custom built for the movie 'Howard the duck'. It was a George Lucas movie between his Star Wars epics. This 'special' movie aircraft was flown by Lyle Byrum in the back seat, with 'Howard' in the front. The very low time aircraft was ordered broken up after the movie use as they didn't want any liability. Everybody got a lot of near-new parts from it, and they disappeared pretty quickly !... I wasn't 't aware they were aerobatic, and it didn't dawn on me to do aerobatics in the one I flew. Lyle Byrum, the original Mr Eipper did break one at the Salinas International Airshow in California in the late 80s, whilst performing aerobatics. He had a ballistic chute fitted and used it, I believe it may have been a king-post failure, and one wing folded. Pretty spectacular at the time, and a good advert for the ballistic chute.. The MXL had a nice double- surface wing similar to the MXl2 and good ailerons . From memory power was the Rotax 337. Later models which came out were called the MX 'Sport' and it went back to a single surface wing, which didn't look anywhere near as pretty.........Maj......
Guernsey Posted September 18, 2013 Posted September 18, 2013 I did the same thing in my Tyro several years ago; I managed to do four loops then fell off the top of the fourth and went into a violent inverted spin, fortunately at around 300 feet my alarm clock went off and I woke up before hitting the ground !!! I am very lucky to still be around and able to tell you this 'unbelieveable story'. Alan. 2
David Isaac Posted September 18, 2013 Posted September 18, 2013 You are a (nice) clown Alan ... LOL Many years ago, about 1982, I tried to spin the Frank Bailey designed 95-10 Mustang (wire braced version of the Javelin in my Avatar). This was before the AUF really existed and I was flying Ultralights on my GA license. It was just not possible ... trying to get it to stall conventionally was impossible, it would just go into a moderate sink rate. So I tried to get it to stall using the hammer head technique with full power and a vertical pull up. When it did stall, it dropped the nose and as soon as it had about 15 knots speed it just flew again, it was just NOT possible to get anymore than a large yaw as it started to fly, spin rotation at all. So Frank achived his objective, an unspinnable plane that you could teach yourself to fly.
