G-OMER Posted December 21, 2012 Posted December 21, 2012 Hi Has anyone got a through bolt torque up plan, i.e which nuts in order to torque up on a 2200 engine Cheers Gary
brilin_air Posted December 22, 2012 Posted December 22, 2012 HiHas anyone got a through bolt torque up plan, i.e which nuts in order to torque up on a 2200 engine Cheers Gary Hi Gary, start at the bolts in the centre of the engine and work out to the ends making sure that you torque both of the nuts on each through bolt. cheers Brian
facthunter Posted December 22, 2012 Posted December 22, 2012 Do them incrementally as well. ( A number of stages ). Most aero engines are never retorqued as far as I know. Somethingis going wrong if they need tightening. There is no gasket to give and require retorquing. By retorquing them you are checking them, but if you are actually moving them I would be a bit concerned. The head bolts are a different matter. The ones near the exhaust valve do have to be torqued from time to time, (Check them all) because the metal yields a bit with the heat cycles.Nev
jetjr Posted December 22, 2012 Posted December 22, 2012 Download the current manual, it's all in there Latest versions for engine and airframe are quite good
G-OMER Posted December 22, 2012 Author Posted December 22, 2012 hi, i was after a map, or layout so i can number the bolts in order of torque up. soon to do a topend on the jab for de cock and 1barrel to come off with suspected sticky rings
Clive J Posted December 23, 2012 Posted December 23, 2012 hey Gaz, you get about...... If you (we) are only taking one barrel off we'll just torque up the bolts we undo, as mentioned above gradually going opposite as much as you can with 4 bolts..... U just did the course, what did Roger (the wise one) say? They have some good smilies on here....
G-OMER Posted December 23, 2012 Author Posted December 23, 2012 clive, i think if you remove 1 barrel, then the knock on will affect all the barrels if you think about it, so a full torque up is reqd. i am being lazy, hoping somone has done a map to save me from working it out
