Guest GraemeM
Does anybody have a how-to on removal of an E box from a 582?
I am wanting to flip it over and don't know if there are any traps waiting for me.
Thanks for any help.
Graeme.
Bloody hell if you had of said we could have done it the other arvo, before that seafood feed you shoved into me, no traps from what i recall, all the bolts come out, and i think 1 or 2 dowls to locate it so take all the bolts out and smack it with a rubber hammer a couple of times it should just jump apart, might as well do the bearings while you got it apart, just push down on the main gear with the prop hub end supported, and the 2 hmmm might be 3 retainers similar to valve spring retainers are removed, then let the spring push the pulley off for you
