johnmon Posted March 8, 2013 Posted March 8, 2013 Hi, my sense of direction is terrible, I need a g.p.s but what to buy? Would like to be able to use it in both plane and car, dollars as always are limited. HELP.
Neil_S Posted March 8, 2013 Posted March 8, 2013 Hi, my sense of direction is terrible, I need a g.p.s but what to buy? Would like to be able to use it in both plane and car, dollars as always are limited. HELP. Hi John, I have a cheap and cheerful Garmin 196 - can be used in both plane and car (although I have not used it in the car). Has no colours or fancy stuff, but you get what you pay for. I am sure there are others too. Cheers Neil
kgwilson Posted March 8, 2013 Posted March 8, 2013 Check out The Recreational Flying 5" & 7" units Ian has to offer at a very good price in the Clear Prop Shop http://www.clearprop.com.au/gps/gps-units.html
flyerme Posted March 9, 2013 Posted March 9, 2013 Check out The Recreational Flying 5" & 7" units Ian has to offer at a very good price in the Clear Prop Shop http://www.clearprop.com.au/gps/gps-units.html I have the Rec 5 " bought from this site,Its awesome.and cheap...does both aviation and automotive 1
Patrick Normoyle Posted March 10, 2013 Posted March 10, 2013 I love my Garmin 196, in a mount and with an external antenna, great for supplementing my situational awareness, but Ozrunways has to be the BOMB, it is awesome, on an iPad 3 gs, can only use it as a situational awareness tool, but it is truly AWESOME ! Plus the iPad has so many uses and you can use the street maps that are provided.
Patrick Normoyle Posted March 10, 2013 Posted March 10, 2013 You'll never get lost or lose situational awareness ever again, just remember to use your paper maps and charts plus required paperwork when you fly. A side note, get a good Belkin charger that has two USB slots, one for your phone and the other for your iPad, the cheap ones tend to emit static or EMR through the electrical system, the good ones are really clean.
Yenn Posted March 10, 2013 Posted March 10, 2013 I use a Garmin 196 and it has all I need. Forroad use it can sometimes be off to one side of the road, but it has the general direction OK. In the air I can't fault it. It has an instrumenr screen, similar to the aircraft instruments, but of course it is GPS derived, so GS, not Airspeed.
Tony Welch Posted May 8, 2014 Posted May 8, 2014 I have the Rec 5 " bought from this site,Its awesome.and cheap...does both aviation and automotive Hi just brought one also needs downloads where do you find them. Thanks
cscotthendry Posted May 8, 2014 Posted May 8, 2014 Whatever you look at buying, ask if you can take it out of the shop and view the screen in bright daylight. That made the choice for me to buy the Garmin 495 rather than the newer Aera units. The 495 has a transflective display but the Area units only had a transmissive display. 2 1 1
Aldo Posted May 8, 2014 Posted May 8, 2014 Hi, my sense of direction is terrible, I need a g.p.s but what to buy? Would like to be able to use it in both plane and car, dollars as always are limited. HELP. If you are not able to navigate by clock, map and compass as you are supposed to be able to as a VFR pilot maybe you shouldn't be flying?? Read the rules, gps secondary only. 4
solowflyer Posted May 8, 2014 Posted May 8, 2014 I just use a. Cheap garmin e trax tells me everything I want to know. Just enter the coordinates then follow the arrow
spacesailor Posted May 9, 2014 Posted May 9, 2014 I learnt the sextant nav, But its too bloodi heavy & slippery when your hands are wet, two expensive lumps later I changed to GPS, going from 10 mile fix to 50 metres acuracy was a revalation. Paper charts are only as good as the pencels used on it. spacesailor
andrew1975 Posted May 10, 2014 Posted May 10, 2014 Garmin aero 500 is awesome, so many features. Worth a look.
metalman Posted May 11, 2014 Posted May 11, 2014 I looked around and ended up with a Garmin 495, I looked at the aeras but the thought of trying to input something in turbulence sold me on not having a touch screen, I have an iPad which works great but if it's bumpy I'll get all sorts of stuff coming up on the screen, not the end of the world but it can be distracting. I'm all for being able to nav without the toys ,but the question here wasn't about using a GPS as primary ,it was just about what brand works best in the opinion of those that use them, maybe a good question would be " who NEVER uses anything other than a chart ,clock and compass? Matty
Aldo Posted May 11, 2014 Posted May 11, 2014 but the question here wasn't about using a GPS as primary ,it was just about what brand works best in the opinion of those that use them, maybe a good question would be " who NEVER uses anything other than a chart ,clock and compass?Matty Matty, I also use a 495 and they are very good, I would think (providing you are able to afford one) you're not using all the tools at your disposal if you don't have one (a GPS) especially if you are doing some serious cross country, the work load reduction is substantial. Johnmon's statement was, "Hi, my sense of direction is terrible, I need a g.p.s but what to buy?" this is not telling me that he is competent with chart, clock and compass as you are supposed to be. A GPS will not help you if your sense of direction is terrible, you still need to know where you are going and where everyone else is in relation to you, if you don't then you are an accident waiting to happen and I don't want you flying anywhere near me. Aldo 1
Blueadventures Posted May 11, 2014 Posted May 11, 2014 Hi, my sense of direction is terrible, I need a g.p.s but what to buy? Would like to be able to use it in both plane and car, dollars as always are limited. HELP. Hi John I the mio navigator is a bottom line unit that has car maps and Wac charts on. Can only be used for position on chart display and has other info displayed including route, way points, airfields speed, direction etc can be as sheap as $80.00. The one sold on this site is similar but better. PM me if you require more info. eg I could email you a screen shot of the display. Cheers Mike
Guest ivan4ilse Posted May 12, 2014 Posted May 12, 2014 I have the Rec 5 " bought from this site,Its awesome.and cheap...does both aviation and automotive Maybe I am going blind but don't see the "Rec" GPS's on the link provided, am I missing something? I am also in the market for a simple cheap but reliable GPS. Could some one please point me in the right direction...
eightyknots Posted May 12, 2014 Posted May 12, 2014 Maybe I am going blind but don't see the "Rec" GPS's on the link provided, am I missing something? I am also in the market for a simple cheap but reliable GPS. Could some one please point me in the right direction... These are the GPSs sold by Clear Prop currently: http://www.clearprop.com.au/index.php?subcats=Y&status=A&pshort=Y&pfull=Y&pname=Y&pkeywords=Y&search_performed=Y&q=gps&dispatch=products.search&page=1
Jabiru7252 Posted May 12, 2014 Posted May 12, 2014 I use a Garmin Nuvi. It's just a car GPS set to off road mode. I enter my flight path (Say, Gawler, Murray Bridge, Loxton Gawler.) It draws a purple line between each town or waypoint and as I fly I leave a blue line. I can see how well I am tracking and the moving map shows the towns etc. as I approach and pass them. No airspace displayed (it's not an aviation GPS) and only miles or kilometres, but hell, it does a splendid job of backing up what all real pilots use, that is, a map and compass. I can upload the .gpx file straight into Google Earth and see how well I stayed on track. I can even replay it! See attached picture as an example. 1
flyerme Posted May 12, 2014 Posted May 12, 2014 Yeh seems they not avail anymore? I now use oz runways on I pad . but any auto gps can be turned into simple aviation gps with moving plane , plans etc... I also run my car gps with Ozzie explorer and have WAC charts downloaded into it.. ( just a back up)It was very simple to download and install! Then I installed my WAC charts ( simple again) . And pretty much the same as the old rec gps. 1
eightyknots Posted May 12, 2014 Posted May 12, 2014 I use a Garmin Nuvi. It's just a car GPS set to off road mode. I enter my flight path (Say, Gawler, Murray Bridge, Loxton Gawler.) It draws a purple line between each town or waypoint and as I fly I leave a blue line. I can see how well I am tracking and the moving map shows the towns etc. as I approach and pass them. No airspace displayed (it's not an aviation GPS) and only miles or kilometres, but hell, it does a splendid job of backing up what all real pilots use, that is, a map and compass. I can upload the .gpx file straight into Google Earth and see how well I stayed on track. I can even replay it! See attached picture as an example. I wonder why your GPS shows the Unmanned Aerial Vehicle site just north of Truro Flats?
Jabiru7252 Posted May 12, 2014 Posted May 12, 2014 " I wonder why your GPS shows the Unmanned Aerial Vehicle site just north of Truro Flats?" We (at work) were there testing some model planes. I guess I could remove that waypoint from my GPS as I only added it so I could find the place by road. 1
Guest ivan4ilse Posted May 13, 2014 Posted May 13, 2014 Thanks for the replies, seems like they don't exist anymore. Like the idea of using the auto GPS and moving plane. How is this done as I am technology challenged?
Jabiru7252 Posted May 13, 2014 Posted May 13, 2014 Thanks for the replies, seems like they don't exist anymore. Like the idea of using the auto GPS and moving plane. How is this done as I am technology challenged? You can always Google how GPS works.
