PatrickF Posted April 18, 2013 Posted April 18, 2013 Guys, I know a lot of you use OzRunways and fly out of spots not on the charts. Am hoping this tool helps you get all those spots onto your maps: http://help.ozrunways.com/kb/getting-started/importing-custom-waypoints Thanks to Rowan and the guys from OzRunways for their assistance (and a brilliant tool) Enjoy
PatrickF Posted April 20, 2013 Author Posted April 20, 2013 Glad some people have picked this up - hope you get some use out of it. Drop me any feedback/suggestions or let me know how you are using it. Happy to receive .ozpln files of your favorite locations ;) I'll add them to my growing must visit list. 1
Heli tracks Posted May 4, 2014 Posted May 4, 2014 Hi there, Excellent tool for importing waypoints. I often have aerial burning flights with very curved tracks that need to be followed. Upwards of 250 waypoints required in some cases!. Was wondering if there's a way to import a larger number of points at once? i.e. so it's a single plan when imported?. Thanks,
PatrickF Posted May 4, 2014 Author Posted May 4, 2014 No problems Heli tracks. I have done a modified version for another guy who flies choppers. It does 200 in a hit. Once you get up around these number OzRunways seems to struggle a bit but that might be hardware related - I'm not sure. Send me an email to the address in the instructions page or PM me and I'll drop you a copy
Russ Posted May 5, 2014 Posted May 5, 2014 Maaaate, if this is the " easy " method......the alternative must be just for rocket scientists. Is there a system for dumb *rses .....ie...me.
Kyle Communications Posted May 5, 2014 Posted May 5, 2014 Ok so the question needs to be asked....who has a master file with all those fantastic waypoints that way we can just do the cut and paste
PatrickF Posted May 6, 2014 Author Posted May 6, 2014 Maaaate, if this is the " easy " method......the alternative must be just for rocket scientists.Is there a system for dumb *rses .....ie...me. Sorry Russ. Have you had a look at the video on the OzRunways site ? Provided you are happy to work in a spreadsheet you should be ok. The video makes it look more complicated than it needs to be. At it's simplest if you just delete my data and type in a collection of Lat and Lon (the green cells) and add a name (code 3) then press generate you have it
PatrickF Posted May 14, 2014 Author Posted May 14, 2014 Sorry Russ. Have you had a look at the video on the OzRunways site ? Provided you are happy to work in a spreadsheet you should be ok.The video makes it look more complicated than it needs to be. At it's simplest if you just delete my data and type in a collection of Lat and Lon (the green cells) and add a name (code 3) then press generate you have it Picking up on Russ' point I've done a simplified version that removes some of the confusion, particularly around Names which are not transferred to OzRunways for imported points. To use simply over type Lat/Lon in decimal or Deg/Min and add an entry in the ID cell (All green cells). Press the generate button and you're done. If you want to name the point add name to one of the code cells. If not it will be named by the lat/lon. Should be available on the OzRunways web site as well shortly. OzRunways_Userpoints_Rev1.5.zip OzRunways_Userpoints_Rev1.5.zip OzRunways_Userpoints_Rev1.5.zip
