frank marriott Posted April 25, 2013 Posted April 25, 2013 What classification is a 28-XXXX rego? I can find 10, 19, 24, 25, 32, 55 listed but not 28.
ruffasguts Posted April 25, 2013 Posted April 25, 2013 What classification is a 28-XXXX rego?I can find 10, 19, 24, 25, 32, 55 listed but not 28. the old amature built VH registered transfered to Raaus Mick
horsefeathers Posted April 25, 2013 Posted April 25, 2013 Uhhhh, my CFM home built shadow is 28 reg - it was never VH registered. I cant give a definitive answer, but believe it is the same as the 19 reg, but limited to 450kg MTOW Try this link http://www.recreationalpilots.com.au/recreational-aircraft-categories.htm Cheers Gerry
planesmaker Posted April 25, 2013 Posted April 25, 2013 28 rego refers to aircraft built under 101.28 regs ie amateur built aircraft as opposed to experimental(19 rego) . They built under saaa with all inspections and no deviations from plans without reg 35 approval. It was how it was done before experimental category came in. I believe builders can still choose to build under 101.28 if they choose. Tom
