Hi all.
Can anyone shed light on whether there is a great difference in the accuracy of an old style 'Westach' type needle tachos vs rotax 'clock style' item.
Have been flying a 503 powered craft with the former which is rather hard to read and wondered whether the accuracy is ok or whether it is just the small scale of the display which is the problem. aviasport.gif.3816a3d454e31581a5891f5b7644b415.gif
Guest Maj Millard
Hi Sebb, I've used both over the years, and they are both ok, however I'd go with the aviasport one if I had a choice for better quality...........Maj...014_spot_on.gif.1f3bdf64e5eb969e67a583c9d350cd1f.gif
Guest Maj Millard
Not familiar with the digital tach at all. The go-cart folks use a lot of Rotaxs maybe they would know a bit about it. The Rotax tach pulse is not that complicated, as long as you can find something that is accurate enough and reliable........Maj....
Tinytach are great... But more expensive...Make sure you set the cycle/stroke right.
  Quote
Ah - have heard of the tiny tachs - might be worth a look!
Just a 'heads up' on Tiny Tachs - they are LCD and as such can sometimes be a bugger to interpret in bright sunlight.
Thanks Riley- good point.
Given the $29 outlay, I just ordered the cheapy on eBay to do a ground calibration exercise, but depending on the outcome, will then see whether an upgrade is needed. A tiny tack in the cockpit would e handy though....
