Admin Posted September 1, 2013 Posted September 1, 2013 [parsehtml] Date Aircraft Location Time Summary Link(s) Times (Pilot) 28-Aug-13 Hornet Gloucester, N.S.W. 1030 Engine stopped during test flight, wasrestarted, then stopped again. Successful emergency landing carried out in paddock east of Avon River. Nil injuries. Substantial damage. [/url] Thread Media TT: 969+ TT on Type (Dual): TT on Type (Solo): 20-Aug-13 Jabiru J170 Victoria Point, Queensland 1100 In flight engine failure following departurefrom YBAF. Forced landing in paddock. Nil injuries. Thread Media TT: TT on Type (Dual): TT on Type (Solo): 16-Aug-13 Jabiru J200 Parkinson, Brisbane, QLD 67 y.o. pilot crash-landed in trees duringapproach into YBAF. Nil fatalities. Substantial damage. Thread Media TT: TT on Type (Dual): TT on Type (Solo): 24-Jul-13 Thruster 10 miles east of Echuca, Victoria Engine failure. Force-landing. Nil injuries. TT: TT on Type (Dual): TT on Type (Solo): 20-Jul-13 Fly Synthesysis Texan Club 550 Howatharra, W.A. 915 Sheared locating pin caused nosewheel to jamfull left during take-off roll. Nil injuries. TT: TT on Type (Dual): 21.5 TT on Type (Solo): 35.37 20-Jul-13 Jabiru C170 Thangool (YTNG), Qld. 1130 Power loss at 2,500' while 2.5 NM fromairfield. Pilot reduced power and able to maintain minimum descent rate. Landed without further incident. Engine TTIS: 966.4 Engine TSOH: 20.7 TT: TT on Type (Dual): 21.5 TT on Type (Solo): 35.37 18-Jul-13 Jabiru J160C Clifton (YCFN), Qld. 1100 Oil cooler leak caused cockpit to fill withsmoke while in circuit. Safe emergency landing completed. TT: TT on Type (Dual): 50 TT on Type (Solo): 30 18-Jul-13 Jabiru J170 Bathurst (YBTH), N.S.W. 1445 Solo student suffered prop strike whilelanding in moderate turbulence with negligible cross-wind (9 kts) TT: TT on Type (Dual): 14.1 TT on Type (Solo): 1.2 14-Jul-13 Thruster T300 Falconhawk Airfield, Boxwood, Victoria 1400 Aircraft bounced while practising cross-windlandings. Subsequent left wheel strike snapped u/c spring assy. bolt, causing ground loop (after wheel and spring dug into soft grass). Nil injuries pilot or instructor. TT: 2849 TT on Type (Dual): 260 TT on Type (Solo): 20.0 7-Jul-13 Skyfox Gazelle CA25 Casino (YCAS), N.S.W. 1050 Engine failure in the YCAS circuit. Crashlanding short of the runway. Substantial damage. Nil injuries. Post crash inspection indicates carburettor bowl may not to have been reseated correctly, allowing air injestion and fuel leaking. Engine TTIS: 334.5 Engine TSOH: 36.6 Thread Media TT: TT on Type (Dual): TT on Type (Solo): 30-Jun-13 Jabiru J160C Lilydale (YLIL), Victoria. 1500 Inflight failure of cylinder valve stem causedengine to run rough (then quit) while descending inound through 1600'. Successful emergency landing. Nil injuries or airframe damage. Engine TTIS: 800 Engine TSOH: 25 TT: TT on Type (Dual): 26 TT on Type (Solo): 158 26-Jun-13 Morgan Sierra Gawler (YGAW), S.A. 1400 Pilot undergoing BFR stalled 4' above runwayduring attempted landing, resulting in nose-wheel collapse. Pilot had not flown during previous seven months. Nil injuries. TT: 158 TT on Type (Dual): 7 TT on Type (Solo): 148 25-Jun-13 Jabiru J170 Archerfield (YBAF), Qld. 1730 Solo navex student landed 8 minutes after lastlight. Contributing factors for delay included stronger than expected headwinds, and unplanned full-stop landing at YKRY. TT: TT on Type (Dual): 28 TT on Type (Solo): 13 25-Jun-13 Aeroprakt A22l Foxbat Langwell Station, via Broken Hill, N.S.W. 1100 Gust caused aircraft to lift, then stall,during landing flare. Pilot unable to regain control. Aircraft written off during subsequent impact. Nil injuries. TT: TT on Type (Dual): TT on Type (Solo): 971 24-May-13 SkyRanger V Max Wonthaggi (YWON), Victoria 1430 Engine spluttered, surged, then stopped afterapprox ninety minutes of continual operation. Substntial damage sustained during forced off-field landing. Nil injuries. Engine TTIS: 145 Engine TSOH: 45 TT: 75.1 TT on Type (Dual): TT on Type (Solo): 23-May-13 Jabiru J230 Enroute Narrandera (YNAR) - Matong, N.S.W. 1400 No.4 exhaust valve failed while cruising2,500'. Successful force landing in paddock. Nil injuries. TT: TT on Type (Dual): 50 TT on Type (Solo): 400 9-Mar-13 Kitfox III Booleroo Centre YBOC,S.A. 1000 Pilot unable to correct starboard driftfollowing touch and go landing. Left main wheel impacted and sheared during attempted go-around. Nil turbulence, insignificant cross-wind. Sunstantial airframe damage, nil injuries. TT: 291 TT on Type (Dual): TT on Type (Solo): 12 [/parsehtml] 9 8
