Re Engining an N3 Pup?
Guys,
Been meaning to get to asking about this for a while.
The N3 appears to have been built around the half vw in its various guises. However I'm pretty sure I've seen them with Rotax 447 and 503.
Could a 503 and 3 blade be fitted in place of the half vw? It would be a 10 reg.
Big Kev
Thanks Guys. The Mosler is about 80 lb. Ideally I'd fit a 1600 vw but that's twice the weight and would definitely upset the balance........
I guess my question is, with all the other interesting licencing stuff that has gone on recently, would it be legal?
I fit in OK despite being 198cm, but it would be always operating very near mtow, so I was after some spare thrust.
Guest Mark_hwltt
The for runner to the N3 - the J3 kitten had a 502 but was under powered so the N3 was powered with the Global then the Mosler - hard to beat the Mosler for economy , spares .
No Spares for the J1600.
I went thru the exercise of different engines with my N3, but decided in the end the Mosler was a good fit. About the only thing I would like to do would be the upgrade from Hummel Engines ( longer throw crankshaft, bigger piston's and Cyl's) some machining of the cases would be involved.
would it be legal?
Being a 95:10, you can pretty much do what you want.
Would be a good idea to keep under the manufacturers MTOW, but check up to see if the is a structural MTOW, or just a legal MTOW for the US?
J3 kitten had a 502
The J3 Kitten was originally designed for the 277 under FAR 103, but could take up to a 503 (or equivalent) if registered (in the US).
Remember, the Mosler 4 cylinder version of what is really a VW, only put out about 50hp (bit less than a 503)
The Mosler 2 cylinder was lucky to put out 30hp, and was heavier than a 503.
Some people are just afraid of two strokes, and want to believe they can get power from a four stroke...... sad.
I think the biggest advantage with 4 strokes is their fuel consumsion compared to 2strokes
As an Engo I can see both sides of 2 and 4 stroke argument.
With the N3 I'd be after the best power/ weight ratio I could get. Ideally, I'd go for more torque and lower revs of a standard 1600 VW, but sticking 160lb on the poor mite would kill it.
A big block Mosler (94mm x 86mm) would do the job admirably, I'd imagine, but I'm a wendy as far as hand cranking goes, so there is weight to be added.
